where is the 1994 civic diagnostic port.
Old 01-06-2010, 09:18 PM
civic90242's Avatar
Default where is the 1994 civic diagnostic port.
i dont know where it is at
does anyone know where it is at?
Old 01-06-2010, 09:20 PM
vtechjunkie's Avatar
Default Re: where is the 1994 civic diagnostic port.
Under the dash, on the passenger side of the car. If it hasn't been tampered with it will have a green sleeve over it. Otherwise, it is a brown two wire plug.
Old 01-06-2010, 09:32 PM
civic90242's Avatar
and im new to this honda stuff. so is the port a obd2 or obd2?
Old 01-06-2010, 09:35 PM
EL Vap133's Avatar
Huh? obd2 or obd2 you ask?
IIRC, the 94 Civic should be an obd1.
Old 01-06-2010, 09:38 PM
civic90242's Avatar
my mistake, my bad
ok thank you i thought it was a obd2
Old 01-06-2010, 09:41 PM
Just connect the two ports with the key in "on" position, and the check engine light will flash. Long flash is 10 and short is 1.
Old 01-06-2010, 09:45 PM
civic90242's Avatar
ok thanks bro
Old 01-06-2010, 09:50 PM
darkenedsol's Avatar
Okay-since no one brought this up,
Pre-1996= OBD 1 Datalink under pass dash-
1996-Present= OBD 2 16-pin Dataport under driver-side dash under steering wheel
OBD= On Board Diagnostic
1= 1 O2 sensor per engine bank, used for ECU fuel trim/compensation
2= 2 O2 sensor per engine bank, 1 upstream before catalytic converter (cat), 1 downstream after catalytic converter (cat) downstream used for ECU monitoring of catalytic converter efficiency.
Hope this helps!
Old 01-06-2010, 09:52 PM
civic90242's Avatar
Hope this helps!
really good info, thanks
Old 01-06-2010, 09:54 PM
Oh, and for clarification, to decipher the code for the check engine light, you can plug a paper clip into the datalink connector on the pass side of the car, and count the flashes with the key on, engine off. the long flash indicates the first number, and the short flash indicates the second number. Ex., two long flashes, two short flashes equals code 22. Good luck!!!
forbiddenera
11-24-2017 05:57 PM
EL TYPE R
11-13-2011 12:00 AM
Bangher4$
Engine Management and Tuning
03-12-2009 06:42 AM
3litre190
08-29-2007 04:24 PM
ef ect
12-23-2002 08:53 PM
Quick Reply: where is the 1994 civic diagnostic port.
