what Type of Coolant should I use?
Old 07-08-2009, 12:57 AM
dth0ng69's Avatar
Default what Type of Coolant should I use?
I have a 1998 Honda civic CX,and I want to do a radiator flush, what coolant should I use? Honda?
would prestone 50/50 coolant work? what should the label say?
Old 07-08-2009, 01:16 AM
Ruben19's Avatar
Default Re: what Type of Coolant should I use?
prestone is fine
Old 07-08-2009, 01:36 AM
MHDesigns's Avatar
I live in arizona. The only reason I don't use water for coolant is because coolant has corrosion resistance to internals lol. The coolant you use does not really matter..as long as its actual coolant and properly mixed.
Old 07-08-2009, 03:13 AM
geneeunit's Avatar
i use honda type 2 coolant. i think with coolant it's more of a preference thing, i think they're all GENERALLY the same.
Old 07-08-2009, 03:39 AM
hondamark35's Avatar
green type... avoid anything orange. blue is ok, but it costs more. i like to mix it myself 50/50, mostly to avoid buying a half gallon of water from autozone
(yes, this was oversimplified to make the point that it doesn't matter as long as you avoid dexcool-orange stuff)
Old 07-08-2009, 03:44 AM
MHDesigns's Avatar
is there really blue coolant? or was that a joke..damn the internet and its lack of a sense of sarcasm lol. But for real that would be jdm as **** lmao!
Old 07-08-2009, 03:49 AM
haha, there was a small amount of sarcasm.. but the Honda Type 2 i think is blue..
i've also seen red in some toyotas... but i figured it's close enough to orange and far enough from green to be avoided.
Old 07-08-2009, 04:00 AM
thi3v3z's Avatar
Well i see you live in seattle, so you should actually mix more coolant and less water because of the harsher winter weather. You should consider 60% coolant and 40% water so you should mix it yourself.
Old 07-08-2009, 06:12 AM
koa
koa's Avatar
I like to use 80% water and 20% coolant and a bottle of water wetter. The summer is pretty hot in TX. In october i flush it again and use prestone 50/50. I have about twenty cases of that **** sitting in my shop. Along with other brands of coolant.
Old 07-08-2009, 06:56 AM
honda.lioness's Avatar
The water pump bearings of older (and newer?) Hondas are known to be vulnerable to non-OEM coolants, with some exceptions. I have been using the orange Havoline Dexcool in my Honda for almost seven years (changing every 2 years or so, which is probably too often) and have had no problems. I have had problems with early water pump failure before when using the green Prestone. I know other Honda veterans who swear by the orange Havoline Dexcool as well.
The only coolants I would use are OEM or the orange Havoline Dexcool. I buy the Dexcool undiluted, since this saves money, picking up a gallon of distilled water at the grocery for mixing.
Old 07-08-2009, 07:49 AM
vtechjunkie's Avatar
I like to use the water wetter as well. It can drop the temp in the radiator a few degrees all by itself. But yes; as "koa", said I would use more coolant than water in the winter. I change mine out every spring with the Prestone and Water Wetter to help with the heat.
SlowEJ8
04-16-2009 02:37 PM
RGoose18
08-11-2006 04:38 PM
DXturbo
09-08-2003 01:56 PM
T_Rex
11-09-2002 06:21 PM
Duck Sauce
11-23-2001 08:49 AM
Quick Reply: what Type of Coolant should I use?
