What are these two holes on D16 block?
Resident Gearhead
Re: What are these two holes on D16 block?
Would be nice if you told us which engine it is. Since I don't see a spot for a knock
sensor, and you say it's a D16, I guess it's a D16Z6 (or whatever they call it in
Germany).
And jbpnoman is right, the green sensor is the oil pressure switch.
And the other hole is not used IIRC, someone correct me if I'm wrong here.
Germany).
pic of my Y8
My block has a plug in the 2nd slot in question. The Z6 in my car is the same way also.
what they said for the green one you usually replace that when going turbo for ur turbo gauge and the other one isnt that to drain the block as well?>
Is that a d16y8? its sitting right up against the cylinder like its a hole for a knock sensor or somthing? :UPDATE:Yup its a knock sensor The D16y8 came with a knock sensor and a crank position sensor and the D16Z6 did not so Im assuming thats a D16Y8. but its not in the same location as yours on your block so im a little confused??
Technical Hero
Pretty sure it's Z6 block. The OBD0 block actually has threads in the second hole for the fan switch. See this link for comparison
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/how-d16z6-block-d16a6-head-2754616/
Technical Hero
I think he may have borrowed the pic from google
https://honda-tech.com/forums/forced-induction-16/stock-oil-cooilng-d16-block-2820019/
dls_tech
12-11-2010 07:36 AM
Charlie Moua
03-10-2010 02:36 PM
600_Double_R
05-28-2006 08:30 AM
