help no power to fuel pump
Old 01-09-2011, 01:26 PM
95blackEG's Avatar
Default help no power to fuel pump
my car shut off while driving, and would not restart.it cranks but the fuel pump does not prime when clicking the key.i have tryed a new main relay n diff ecu, still no fuel pump.i took off the fuel tank acess cover n tested the plug going to the pump which was not getting any voltage.so jus trying to figure what would cause the plug that goes to the pump not get any power.
Old 01-09-2011, 01:44 PM
habib's Avatar
Default Re: help no power to fuel pump
Did the main relay you swaped in good?
Old 01-09-2011, 01:57 PM
delsolintegra's Avatar
The main relay is grounded thru the ECU to the point of the bundle of wires screwed to the thermostat housing. Clean the connection of these wires to the thermostat housing. Bet this fixes it.
95blackEG's Avatar
it was brand new
Old 01-09-2011, 02:01 PM
Former User's Avatar
95 Civic, right? Check hood fuse 31 and dash fuse 24.
Old 01-09-2011, 02:05 PM
95blackEG's Avatar
[QUOTE=delsolintegra;44388018]The main relay is grounded thru the ECU to the point of the bundle of wires screwed to the thermostat housing. Clean the connection of these wires to the thermostat housing. Bet this fixes it.[
these bundle of wires are under the hood?
Old 01-09-2011, 02:40 PM
Old 01-10-2011, 03:45 AM
yeah. under the hood. the thermostat is on the engine block where the radiator hose goes in to the engine
Old 01-10-2011, 03:53 AM
there was probably nothing wrong with the old main relay. if you just cleaned the ground point on the thermostat housing it would have worked. new or old relays will not work if you don't clean the ground connection on the thermostat housing.
Old 03-06-2011, 06:40 AM
96lsvtec-t's Avatar
fixed? what did you find?
wtfisvtec??
36
08-16-2023 07:31 AM
Hightower350
17
05-10-2013 03:53 PM
Efjams24
08-01-2012 01:13 PM
SoFresh1189
17
07-09-2010 07:03 AM
electron_si
02-18-2008 08:17 AM
Quick Reply: help no power to fuel pump
