weird vibration coming from the rear wheels at 65 mph+
Old 07-06-2010, 05:33 PM
killahatch's Avatar
Default weird vibration coming from the rear wheels at 65 mph+
so today i was driving on the freeway around 65 and i noticed every few seconds the rear would shake side to side, and i kinda figured the lug nuts were loose, so i got home and they were tight. any ideas of wat it could b?
a few things about the suspension: its on ground control coilovers, tokico blues all around, new lower control arms, and rear camber kit, and the wheels were balanced and rotated . i also lifted the car and noticed the trailing arm bushings were torn at the bottom, could this b wats making the vibration?
Old 07-06-2010, 05:41 PM
raidacaipo's Avatar
Default Re: weird vibration coming from the rear wheels at 65 mph+
bad wheel bearing. You need to replace it.
Old 07-06-2010, 05:46 PM
EJeff8's Avatar
Bad tie rod? Or are those only in the front? I'm not the best with suspension.
Old 07-06-2010, 05:47 PM
318 Curves, 11 miles
Vindicator9000's Avatar
yes, could be wheel bearing. Or trailing arm bushings, or bad toe.
Raise the rear up and see if you can wiggle one or both wheels back and forth. That can be an indicator of a wheel bearing.
How bad are your trailing arm bushings, really? It's normal for them to have an opening at the bottom; they come that way brand new.
Check your tires for signs of cupping or feathering that can indicate toe. Another sign might be excessive tire noise from the rear.
There aren't tie rods in the rear.
Old 07-06-2010, 05:51 PM
EJeff8's Avatar
This is why we ask questions. Thank you.
Old 07-06-2010, 05:54 PM
Retired Moderator
EsotericImage's Avatar
This
Old 07-06-2010, 05:59 PM
killahatch's Avatar
i picked it up and wiggled the wheel and it seemed pretty firm, and the car had an alignment maybe 3 months ago with toe and camber in the front and rear.
im gonna do alil more research b4 i start buying parts it may be but those ideas u guys hve thrown at me seem pretty good guesses. thanks
Former User's Avatar
Post pictures of the "torn" bushings.
Old 07-06-2010, 06:01 PM
killahatch's Avatar
ill see if i can get a pic as it is getting alil dark outside. gonna go outisde now and see if i can get a pic up.
Old 07-06-2010, 06:11 PM
killahatch's Avatar
heres a pic. srry for the crap quality, its a cell phone pic and the glare is an led light cuz its dark outside.
Old 07-06-2010, 06:24 PM
I'd replace the badly torn bushings and go from there.
Old 07-06-2010, 06:30 PM
killahatch's Avatar
ya there like that on both sides, prob. just save up for spherical bushings. thanks.
Old 07-06-2010, 06:31 PM
EJeff8's Avatar
^... You sure you have time to save up? I'm surprised you haven't died.
Old 07-06-2010, 06:34 PM
killahatch's Avatar
... this problem just started, idk how long they've been torn, but no i dont need to save up i have the money, i just want to make sure thats wat the problem was. thanks
Old 07-06-2010, 06:37 PM
EJeff8's Avatar
^ It may not necessarily be the problem but it sure as hell needs fixed.
Old 07-06-2010, 06:39 PM
killahatch's Avatar
yes i kno this, i just noticed it wen i went to see wat the problem was. anyways thanks again, it will b fixed asap.
Old 07-06-2010, 07:05 PM
Lol you might be surprised about how many Civics are driving around with TA bushings that look like that. It's pretty common.
I would say that they might be a good start to figuring out the problem.
Kaniela
Honda Civic (2006 - 2015)
08-11-2017 08:42 AM
homeskillet
10-14-2010 02:24 PM
Honduh Uhcord
10-23-2007 03:03 PM
YoungKadafi
Suspension & Brakes
12
12-10-2006 11:42 AM
project civic
03-05-2006 04:29 PM
Quick Reply: weird vibration coming from the rear wheels at 65 mph+
