water temp in normal driving?
Old 07-10-2010, 02:32 PM
Rikaro's Avatar
Default water temp in normal driving?
I just installed a new water temp gauge and my readings are at 230F during a hot summer day. It's a B18c1 motor. It seems pretty hot and I'm unsure if it's normal
Old 07-10-2010, 07:05 PM
Retired Moderator
EsotericImage's Avatar
Default Re: water temp in normal driving?
should be at 180 - 200
did u bleed the cooling system correctly?
Old 07-10-2010, 07:29 PM
shogee's Avatar
yea could be thermostat getting stuck closed
Gunmetal_B20_Hatch's Avatar
200-210 is normal operation temp. 230 is high. You have problems
Old 07-10-2010, 10:32 PM
Retired Moderator
^^ yea, i tend to keep mine running on the cooler side.
Old 07-11-2010, 12:46 AM
97ej6dx's Avatar
yes even a little air can be a Big nightmare. ive had tons of problems after my swap with air in the lines and i always though it was electronic problems but i later found it it was air.. strange how it keeps you alive but some times can be your worse enemy. and the cars
Old 07-18-2010, 11:01 AM
Rikaro's Avatar
I just fixed it. Forgot to check coolant. It's at 190f now. Thanks
Old 07-21-2010, 06:43 PM
Rikaro's Avatar
I am driving it for a bit now and noticed that it gets hotter the longer I drive. What is the overheat temp anyway? I have a mishimoto rad. The only time it cools down is when I idle and when the fan kicks in.
Old 07-22-2010, 10:42 AM
Rikaro's Avatar
Anyone?
Old 07-22-2010, 11:49 AM
Former User's Avatar
Is the lower radiator hose getting hot?
Try bleeding the cooling system.
Old 07-22-2010, 12:13 PM
Retired Moderator
Ive been saying for over a year now..
Mishimoto keeps saying that there slim fans work perfectly in keeping the temps down.. I went thru a 12" and that didnt do anything. I tried their 14" and not much difference.. (there was only like 50 more CFM with the 14")
I went to Xenocron.com and bought their 13" 1300 cfm fan and it works great..
I really think this is why Mishimoto went to a triple core cuz their fans on the dual doesnt seem to work on hot days..
Old 07-22-2010, 01:40 PM
Rikaro's Avatar
Yes both of the hoses are hot. I have an obd2 motor so the only way to bleed it is to open the rad cap while the car is running and squeezing the upper hose. I was wondering if I could mount my stock fan on the mishimoto rad.
Old 07-22-2010, 01:42 PM
Bleeding may take 20-30 minutes:
1) Park the car on an inclined driveway with the front end higher than the rear.
2) Push the dash heater lever/**** to MAX heat.
3) Follow the directions in the diagram below
Old 07-22-2010, 01:46 PM
Rikaro's Avatar
Sweet thanks I'll try that tonight.
The temp should never exceed 200f on normal driving right?
Old 07-23-2010, 09:19 PM
Rikaro's Avatar
Just bleed it today. It didn't work. I was peaking at 230f.
When I was driving and was at 190 for a while then it went up.
olddohc
12-18-2011 08:35 PM
dc4b20
11-24-2007 11:26 AM
Hondaciv95VX
01-13-2005 07:21 PM
superstud
03-14-2004 08:54 PM
Quick Reply: water temp in normal driving?
