Water sloshing behind seats
Old 10-11-2014, 10:30 AM
WardNL's Avatar
Icon2 Water sloshing behind seats
Hi guys,
I have a problem with my Sol. I can hear water sloshing sloshing around behind the seats whenever I'm cornering.
How can I get rid of this?
Cheers,
Eduard
Attachment 522686
Old 10-11-2014, 11:01 AM
Ferio Wdm Edition
ferio-ichi3's Avatar
Default Re: Water sloshing behind seats
Take the seat out and see whats causing it.
Old 10-11-2014, 07:33 PM
Retired Moderator
EsotericImage's Avatar
Fuel tank?
Old 10-11-2014, 11:01 PM
Nave43's Avatar
Its a Del Sol problem. You have water trapped in the wall where your rear window goes down into. The rear window acts as a drain of sorts from the roof and sometimes water tend to collect there. You are not the first, this problem is almost as common as the sail panel leaks...
You will have to remove your personal trunk to get to the problem and remove the water. I am sure i can find you a how to somewhere.
Old 10-12-2014, 01:51 AM
Nave43's Avatar
Sorry to double post but i cant add pictures through an edit.
There is you sloshing noise \/ Those drain holes are clogged
And here is a DIY on how to fix it THE RIGHT WAY There is even ways to do it without taking out all the interior at the bottom of the DIY. \/
water in rear window? (How To)
Another walk-through from our very own H-T alibeit not nearly as well done, and not specifically for water. Though it does have a nice section about re weather stripping your rear window to prevent the problem from happening again. \/
https://honda-tech.com/honda-civic-d...-trim-2554512/
Lastly if your up for experimentation, there is this \/
"I used someone elses idea and went to Wamart and bought the generic effervescent denture cleanser tablets (equate) for $2.97. I rolled down my back window; dropped 2 tablets on each side and 30 minutes later there was a puddle under my car. I have had the problem of water being held up in this compartment every time it has rained for over 2 years now. Problem solved without any maintenance."
Old 10-12-2014, 05:13 AM
Former User's Avatar
FYI:
Edit Post > Go Advanced
Old 10-19-2014, 01:35 AM
WardNL's Avatar
Nave43
Thanks a lot for that link! I have a few days off, still sunny here... I think I will give it a try.
I'll keep you guys posted.
Old 10-19-2014, 03:53 AM
Nave43's Avatar
Originally Posted by WardNL
Nave43
Very welcome, its why im here
Old 10-19-2014, 10:40 AM
Oh look, I can change this
deschlong's Avatar
Do it soon, OP - before the rust starts.
Old 10-19-2014, 10:47 AM
WardNL's Avatar
Step 1: Ripping out the interior
I squeezed and wiggled the hoses, looked under the car and the water started dripping slowly...
I decided not to take out the window unit and after more squeezing and some tight corner the water started coming out.
Water trail!
Thanks a lot!
Eduard
For the first time in months I gave my sol some TLC. I cleaned the targa roof rubbers, going to grease them up later. Cleaned out gunk in trunk near the rear window and cleaned the rubber strip between hood and bumper.
Old 10-19-2014, 03:35 PM
Nave43's Avatar
You may wanna try the denture cleaner method to really get the gunk loose. Otherwise im glad you fixed your problem. The Borat meme made me laugh aswell.
Old 03-30-2021, 11:30 PM
gmbdelsol's Avatar
Hi, the drain pipes that are located in the rear sideskirts area are for the rear window pleass?
SuppDude1
04-04-2021 08:27 PM
Deesoll
01-21-2014 08:01 AM
whokidd
22
02-24-2011 02:36 PM
Mike Polinder
01-13-2011 01:23 PM
samdawgsol
10-05-2003 07:51 PM
Quick Reply: Water sloshing behind seats
