proof that cam gears do work
Old 01-11-2004, 12:59 AM
JDMlyfestyle's Avatar
Default proof that cam gears do work
Im tired of everyone saying that cam gears are worthless unless you have somewhat major modifications. well i have a book How to build honda horsepower. it has a shitload of dyno comparisons and here is one i found.
Its a b16 with stock cams. 94 octane. Fuel Pressure set at 41 PSI. I/H/E
b16 with bolt ons. 94 octane. fuel press at 41psi. and here are the results of the cam gears
Old 01-11-2004, 01:02 AM
99blackcivicSi's Avatar
Default Re: proof that cam gears do work (JDMlifestyle)
ON a dyno with optimal conditions i can see them working but you arn't going to fell 2-5 hp on the butt dyno and if you can you have the most sinsitve *** eva.
Old 01-11-2004, 01:21 AM
that was a 10 HP gain
Old 01-11-2004, 01:24 AM
2point2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMlifestyle &raquo;</TD></TR><TR><TD CLASS="quote">Im tired of everyone saying that cam gears are worthless unless you have somewhat major modifications. well i have a book How to build honda horsepower. it has a shitload of dyno comparisons and here is one i found.
Good stuff. But what if the cam gears are off 2deg?? 8) and the timming was being played with aswell.
I had an i/h/e setup with cam gears on the dyno and all i did was lose hp whenever i screwed with them... still not convinced ya need them with your basic i/h/e setup.
Old 01-11-2004, 01:28 AM
Tad
Tad's Avatar
i can def see cams making a difference,
they basically move your powerband up or down,
and considering at wot, shifting at redline thru the gears... you actually never even see the lower rpms... so why should you care about that power!?
(well yeah it makes stop'ngo driving ez, but im talkin racin)
Old 01-11-2004, 07:26 AM
STIBungy's Avatar
Wow, stock b16 dyno'd at 162hp?
Old 01-11-2004, 07:31 AM
WangChung's Avatar
Default Re: (B18CBungy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18CBungy &raquo;</TD></TR><TR><TD CLASS="quote">Wow, stock b16 dyno'd at 162hp?</TD></TR></TABLE>
it had i/h/e.
Old 01-11-2004, 07:56 AM
STIBungy's Avatar
I have all those and mine came in at 151
Old 01-11-2004, 08:01 AM
Moderator
chad's Avatar
the problem with that is i hvae seen dyno's vary by 10 hp from one run to another without DOING ANYTHING to the car....you do not know what dyno that test was performed on
and yes cam gears do work!
Old 01-11-2004, 08:07 AM
Multi-paradigm
Good ol' Screwtape's Avatar
it doesn't say whp..but..that's still pretty weird.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18CBungy &raquo;</TD></TR><TR><TD CLASS="quote">I have all those and mine came in at 151 </TD></TR></TABLE>
Yeah, but that's always to be expected with old motors.
BTW..if you have a B16..what does your username mean?
I hope your B18C isn't dyno-ing at 151hp. That's pretty bad.
Old 01-11-2004, 08:39 AM
kingSfit's Avatar
oil change
STIBungy's Avatar
Default Re: (R_EG)
B18C is from my GSR which I traded in for an STI. My civic has a b16a2 in it.
Old 01-11-2004, 09:32 AM
feriocious's Avatar
You're just moving the powerband around. IMO, you're not really making more power, you're just shifting the power curve towards a higher RPM. Those numbers are worthless without the graphs though.
Let's see those graphs
Old 01-11-2004, 10:38 AM
be professional
Targa250R's Avatar
Peak numbers don't necessarily mean anything.
Seeing the entire plot does mean something. It's usually better to tune for the benefit of the entire curve, not just the peak number.
Old 01-11-2004, 10:46 AM
JSPECHB's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18CBungy &raquo;</TD></TR><TR><TD CLASS="quote">B18C is from my GSR which I traded in for an STI. My civic has a b16a2 in it.</TD></TR></TABLE>
Can I lick your STI's window?
Old 01-11-2004, 12:11 PM
STIBungy's Avatar
Default Re: (JSPECHB)
Hehehe, just dont lick the door handle.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JSPECHB &raquo;</TD></TR><TR><TD CLASS="quote">
Can I lick your STI's window? </TD></TR></TABLE>
Old 01-11-2004, 12:46 PM
TeamNextGenChris's Avatar
Default Re: (Scissor)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Scissor &raquo;</TD></TR><TR><TD CLASS="quote">You're just moving the powerband around. IMO, you're not really making more power, you're just shifting the power curve towards a higher RPM. Those numbers are worthless without the graphs though.
Let's see those graphs </TD></TR></TABLE>
exactly.i'm sure you can probably gain a few PEAK HP by playing with them a little,but you could very well be losing as much or more power other places on the graph.i've seen lots of articles on domestic vehicles having the stock cams being produced slightly off timing(like the keyway for the cam gear is machined up to a few degrees off from where it was intended to be),and correcting that can gain a few HP,but you're really only fine tuning back to where the OEM intended it to be to begin with.don't know if this is really an issue with Hondas or not.
cam gears can be very valuable by allowing you to tune in an aftermarket cam or to move around the powerband,but the i don't think a huge,wide power gain is really available with stock cams on a relatively stock motor.
chris
Old 01-11-2004, 01:03 PM
Default Re: (TeamNextGenChris)
Here is the graph's no loss in the powerband
Old 01-11-2004, 01:08 PM
Default Re: (JDMlifestyle)
those are too blurry to really get any info from.any way to get a better scan?
chris
nsxmatt's Avatar
172whp from a B16 with I/H/E and cam gears? Something else is missing...
Old 01-11-2004, 01:09 PM
Jer
Jer's Avatar
cam gears are great for tuning your motor for the most under the curve power though. peak numbers really dont mean ****. you can tune your cams so that maybe you even loose a few peak hp but geain a good bit through the whole mid range.
id rather have more useable power under the curve than have bragging rights of a higher peak number any day of the week.
Old 01-11-2004, 02:22 PM
redman223's Avatar
Default Re: proof that cam gears do work (nsxmatt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxmatt &raquo;</TD></TR><TR><TD CLASS="quote">172whp from a B16 with I/H/E and cam gears? Something else is missing... </TD></TR></TABLE>
Maybe they forgot to mention that it was with the new AEM V2 intake that makes more power than your ordinary CAI (just look at their simulated race on theri webpage)....haha
How much whp do b16's normally make stock with no ac or ps?
Old 01-11-2004, 02:27 PM
toolowsol's Avatar
Default Re: proof that cam gears do work (redman223)
Almost all the dynos in that book are flywheel horsepower. Its an engine dyno, not chassis dyno.
Old 01-11-2004, 02:32 PM
sillvercivicgsr's Avatar
151 on a b16 with i/h/e sounds about right. 162 would be about 20 over stock.
Old 01-11-2004, 02:42 PM
These are not engine dyno results these are WHP. shows pictures of the cars on the dyno.
Quick Reply: proof that cam gears do work
