vtec oil pressure switch bypass........ is it really that simple?
Old 07-18-2006, 08:49 AM
EG type GTR
Guest
Posts: n/a
Default vtec oil pressure switch bypass........ is it really that simple?
based on that diagram, i just cut the a4 and d6 wires on the connector and solder them together and this will give me my missing vtec. is it really that simple?
oh yeah, is there anything special about d3 knock sensor?
Old 07-18-2006, 08:53 AM
philosofy1's Avatar
Default Re: vtec oil pressure switch bypass........ is it really that simple? (EG type GTR)
i don't understand. why would you want to by pass the oil pressure switch?
philosofy1 is offline
Old 07-18-2006, 08:56 AM
EG type GTR
Guest
Posts: n/a
Default Re: vtec oil pressure switch bypass........ is it really that simple? (philosofy1)
i dont have it on my motor for the engine harness green vtec solenoid to connect to.
Old 07-18-2006, 09:02 AM
philosofy1's Avatar
ohh, i was just curious, thanks.
Old 07-18-2006, 11:00 AM
NJcoupe's Avatar
Yes, it works.
NJcoupe is offline
Old 07-18-2006, 12:01 PM
Sleepy_Red_hatch's Avatar
Default Re: vtec oil pressure switch bypass........ is it really that simple? (dxcoupe.)
i dont get it. doesnt ever vtec car have a pressure switch? or is yours just missing/broken and you dotn want to buy a new one?
Sleepy_Red_hatch is offline
Old 07-18-2006, 02:05 PM
BlueIntegraBoy's Avatar
Default Re: vtec oil pressure switch bypass........ is it really that simple? (Sleepy_Red_hatch)
He has a B18C, which doesn't have a pressure switch
BlueIntegraBoy is offline
Old 06-19-2007, 11:24 AM
insidiouseg-6's Avatar
yea..some jdm swaps dont come with pressure switches from the factory...so when u use a usdm ecu...it will look for it and notice it aint there and throw you a code....so u have to by pass it to get it to work
....just trying to clear things up!
insidiouseg-6 is offline
Old 06-19-2007, 12:39 PM
badboyr66's Avatar
Default Re: vtec oil pressure switch bypass........ is it really that simple? (insidiouseg-6)
Useful thread
badboyr66 is offline
Old 06-20-2007, 11:58 AM
Vero's Avatar
This diagram is only for OBD1 ECUs, will this also work for OBD2 by crossing the pressure switch wire with the solenoid wire?
Vero is offline
Old 06-20-2007, 01:41 PM
EJProject's Avatar
I believe you can also map an OBD1 ECU (socketed with an EPROM) to disable the VTEC oil pres. switch as well. But this solution is much cheaper.
EJProject is offline
Old 06-20-2007, 02:09 PM
B16b-EJ8's Avatar
yes for an OBD I to OBD II conversion harness that is exactly what i had to do and it works fine.
B16b-EJ8 is offline
Old 06-20-2007, 06:47 PM
smokerz212's Avatar
can u bypass the vtec pressure switch in b16a2?
smokerz212 is offline
Old 06-20-2007, 07:32 PM
Vero's Avatar
Default Re: vtec oil pressure switch bypass........ is it really that simple? (smokerz212)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by smokerz212 &raquo;</TD></TR><TR><TD CLASS="quote">can u bypass the vtec pressure switch in b16a2?</TD></TR></TABLE>
Sounds like you can from what they said above.
Vero is offline
Old 06-20-2007, 07:35 PM
94typeR's Avatar
to bypass, just look for those 2 wires and get a tap to connect them both
its as simple as it sounds
94typeR is offline
Old 06-20-2007, 08:09 PM
Vero's Avatar
Default Re: (94typeR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94typeR &raquo;</TD></TR><TR><TD CLASS="quote">to bypass, just look for those 2 wires and get a tap to connect them both
its as simple as it sounds</TD></TR></TABLE>
Yup.
Or, for the super lazy, you can buy a bypass switch.
http://cgi.ebay.com/ebaymotors...ZWD1V
Or consider buying the switch itself, tapping it in, and running the wire.
Switch:
Wire Harness:
Vero is offline
Old 08-02-2007, 06:41 PM
civicracer94's Avatar
Default Re: (Vero)
so your sayin hook a4 and d6 together then run it to the vtec solenoid ??
civicracer94 is offline
Old 08-02-2007, 07:27 PM
gentek1145's Avatar
bump this threadfor installed pics@@@
gentek1145 is offline
Old 08-02-2007, 11:09 PM
BlackoutVTi's Avatar
Default Re: vtec oil pressure switch bypass........ is it really that simple? (gentek1145)
Just did it for my car. Everything works fine. I may get some pics up.
BlackoutVTi is offline
Old 08-16-2007, 06:14 PM
JDM-95-Hatch's Avatar
Default Re: vtec oil pressure switch bypass........ is it really that simple? (BlackoutVTi)
does anyone have the vtec solenoid and oil pressure switch pinout for obd2 b16a2 ecu? need to bypass mine also. no oil switch on jdm b16 obd2 motor
JDM-95-Hatch is offline
Old 08-18-2007, 08:48 AM
redlinectr's Avatar
Default Re: vtec oil pressure switch bypass........ is it really that simple? (JDM-95-Hatch)
Check out phearable.net's tech section it'll show you everything you need to know.
redlinectr is offline
Old 08-27-2007, 03:03 PM
GO GIANTS!
HondamanXxX's Avatar
Default Re: vtec oil pressure switch bypass........ is it really that simple? (redlinectr)
With Vtec still work without this Sensor?
HondamanXxX is offline
Old 08-27-2007, 09:54 PM
GO GIANTS!
Anyone?
Old 09-02-2007, 12:11 PM
girlsaremean's Avatar
Default Re: vtec oil pressure switch bypass........ is it really that simple? (HondamanXxX)
i have a question as well. I have a b18c that i put in my 94 eg coupe. used the jdm gsr harness and just swapped it from rhd to lhd. Vtec doesn't work with my obd1p72, so i plug in my stock 28, vtec works. so i drill and tap and install the vtps from my d16z6, no vtec. vtec works with my stock p28, my friends chipped 28, and a ecu from my bros friend in cali. so i got a bad ecu i'm thinkin, so i bought another p72 from a HT member, plug it in..... no vtec. so i've tried doing this vtps bypass on the engine harness, so i'm gonna go out and do it at the ecu connectors right now, but if anyone has any ideas for me, i'll make out with you. thanks
girlsaremean is offline
Old 09-02-2007, 01:01 PM
TeamRiskEG6's Avatar
Default Re: vtec oil pressure switch bypass........ is it really that simple? (girlsaremean)
good thread
TeamRiskEG6 is offline
Quick Reply: vtec oil pressure switch bypass........ is it really that simple?
