Very low idle while coasting
Old 04-22-2009, 01:00 AM
joker4096's Avatar
Icon6 Very low idle while coasting
The idle of my car drops very low when i either rev up the car and let the revs drop or whenever i drive and push in the clutch so i can coast to a light. Idle revs are about 900 rpm and the idle drops to about 500 or less whenever i have the problem. The lights also dim when it reaches below 600 rpm. When the car finally stops, the rpms slowly climb back to normal and its fine. car is a y8/z6 vitara setup w/ y8 intake mani. 5 speed
Old 04-22-2009, 03:30 AM
sde780's Avatar
Default Re: Very low idle while coasting
mine was the alternator, the belt was a bit loose
Old 04-22-2009, 12:08 PM
joker4096's Avatar
I had the alternator and battery checked and they turned out to be fine.
Old 04-22-2009, 01:58 PM
joker4096's Avatar
all grounds were upgraded to 1/0 and the positive from the alt also.
Old 04-22-2009, 02:09 PM
Former User's Avatar
Is the CEL ON? My first impression is a problem with the IACV. Have you tried cleaning it and the throttle body?
JAYSCRX420
10-12-2022 11:24 PM
ozh_hawaiian
09-03-2011 01:24 AM
FOMULA91
14
04-23-2009 07:04 AM
tweekerz
08-12-2007 08:06 PM
calbert0
11-09-2006 04:37 AM
Quick Reply: Very low idle while coasting
