Upstream or Downstream O2 Sensor? interchangable?
Old 11-03-2006, 01:00 PM
TunerShark's Avatar
Default Upstream or Downstream O2 Sensor? interchangable?
my downstream o2 sensor(on cat) is shot, so i just bought a new denso one for my car on ebay, but it doesnt specify wether its the upper or the lower one, i mean, are these 2 sensors interchangable? or are they 2 completely different?
heres the auction
http://cgi.ebay.com/ebaymotors...d=1,1
thanks
Old 11-03-2006, 01:02 PM
Darth ModerVader
Padawan's Avatar
Default Re: Upstream or Downstream O2 Sensor? interchangable? (TunerShark)
They're interchangeable, as far as function goes.
Old 11-03-2006, 01:07 PM
TunerShark's Avatar
Default Re: Upstream or Downstream O2 Sensor? interchangable? (Padawan)
ok cool, so just in case, would an o2 sensor made for the header fit right into where the cat one is supposed to be?, i mean like wiring & fitment wise?
thanks
Old 11-03-2006, 01:15 PM
Darth ModerVader
Padawan's Avatar
It should. I know on the Integra, the secondary sensor has a rubber grommet to seal the hole where it enters the car, and the wiring might be a slightly different length. I'm not entirely certain, but I assume it's a similar situation with the Civic. Either way, it shouldn't be a big issue.
Old 11-03-2006, 06:09 PM
TunerShark's Avatar
ok, what about the plastic connector harness? are they still both the same on upper and lower?
Old 11-03-2006, 06:13 PM
Darth ModerVader
Padawan's Avatar
Yes, the connectors are exactly the same.
Old 11-10-2006, 06:47 AM
yeah_its_fast's Avatar
can i get a picture of where these O2 sensors are suppost to be?? I have a b16a2 and i was told it was missing the o2 sensor. there is a sensor by the cat but not one on the header.
zerodohc
01-10-2013 12:41 PM
TtOrMaMnY
07-04-2008 12:56 PM
EJ8 Kenobi
14
02-25-2008 08:59 PM
PH3593A
10-13-2004 10:14 AM
LostAndFound
18
06-25-2004 10:46 PM
Quick Reply: Upstream or Downstream O2 Sensor? interchangable?
