un-normal Idle Problem
Old 09-03-2007, 05:04 PM
Whig-it's Avatar
Default un-normal Idle Problem
Now i am farmiluar with the honda and their surging idels when cold and stuff. I have a different surging problem. I have tested 2 different iacv both with different results.
#1 Car idles fine till warmed up, and them it surges.
#2 car surges @ idle and when warm
Now the car is a stock 97 civic dx. I am more uset the 2 wire iacv in the older civic and such, so this newer stuff is a little more comfusing to me. thanks for any help
Old 09-03-2007, 05:32 PM
jpkustoms04's Avatar
Default Re: un-normal Idle Problem (Whig-it)
i have had this problem as well. check your coolant level and make sure your thermostat is opening properly
Old 09-03-2007, 06:22 PM
97Ej6mike's Avatar
you mean AB-normal?
Un-normal isnt a word, lol.
Your IACv needs to either be cleaned or replaced. Theres at least 2 post's a day on this, do a search if you are still confused, they arent hard to replace or clean out.
Since you have the d16y7, your IACv is located on the throttlebody itself. Been awhile since i actualy worked on a y7, so i cant remember off the top of my head how hard it was to reach the IAC.
Old 09-03-2007, 06:54 PM
Whig-it's Avatar
well, since i have tested 2 iacv, i know where it is. i ahve cleaned both, and they both more freely. I should try the t-sat tho i believe it's fiarly new.
crxguy406
09-10-2015 03:56 AM
MyEj1Broke
01-10-2014 08:09 AM
dices543
13
11-19-2010 04:07 AM
homeskillet
01-13-2005 05:04 PM
Quick Reply: un-normal Idle Problem
