timing belt fell off!!! please help!!!!
Old 07-31-2008, 10:05 PM
RIPPO's Avatar
Default timing belt fell off!!! please help!!!!
so i don't drive my car very often during the summer months and decided to take it for a spin around the block. i get on the freeway and go about 90 all of a sudden the car felt like i ran over a basketball, i start to hear a knocking noise and pull over. the car still idles so i look around and i got a rear flat tire. i turn the car around and try to drive it home but now the battery symbol is turning on. i have no idea wat's goin on with it and wen i finally got it home i noticed the timing belt is dangling off. do you know what might have caused this or how i can fix it> can i just put the belt back on and adjust it and check the timing????
please help me out thanks
Old 07-31-2008, 10:34 PM
CEMAYHALL's Avatar
Default Re: timing belt fell off!!! please help!!!! (RIPPO)
I'm no mechanic but:
1. If your timing belt was "dangling off" your car, it wouldn't start/ run!
2. Also, you said that your battery light went on.
3. The battery light went on b/c you were driving the car using the battery's power rather than the alternator.
4. Put the alternator belt back on!
5. Stop going 90 mph.
Old 07-31-2008, 11:09 PM
Hemix's Avatar
Default Re: timing belt fell off!!! please help!!!! (CEMAYHALL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">I'm no mechanic but:
Old 08-01-2008, 02:31 AM
actek23's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CEMAYHALL &raquo;</TD></TR><TR><TD CLASS="quote">I'm no mechanic but:
5. Stop going 90 mph. </TD></TR></TABLE>
lol... couldnt have said it any better...
Old 08-01-2008, 03:16 AM
patrickd_21's Avatar
Default Re: timing belt fell off!!! please help!!!! (actek23)
lol
Old 08-01-2008, 04:13 AM
na+b18c_hatch's Avatar
man i hate when my timing belt falls off!!
Old 08-01-2008, 04:21 AM
Cowtit's Avatar
thats why i always use 2 timing belts, gotta have a back up!
Old 08-01-2008, 04:35 AM
EJ8_Enthusiast's Avatar
I always heard you could just use a piece of panty hose for a timing belt as a quick fix =D [/sarcasm]
good luck with that alternator belt.
Old 08-01-2008, 05:09 AM
Default Re: (Cowtit)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cowtit &raquo;</TD></TR><TR><TD CLASS="quote">thats why i always use 2 timing belts, gotta have a back up!</TD></TR></TABLE>
i fixed my motor up to have a timing belt on both sides
Old 08-01-2008, 07:06 AM
srmofo's Avatar
Default Re: (na+b18c_hatch)
that sounds more like muffler bearings to me, you might wanna check those
Old 08-01-2008, 07:17 AM
Default Re: (srmofo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by srmofo &raquo;</TD></TR><TR><TD CLASS="quote">that sounds more like muffler bearings to me, you might wanna check those </TD></TR></TABLE>
no you dummy, mufflers don't have bearings. OP, check your muffler fluid
Old 08-01-2008, 07:50 AM
Cruiserdude's Avatar
Your alternator/ac belt came off. You wouldn't see if your t-belt came off, b/c its under the valve cover and behind the timing covers. Your motor would just cut off and never crank again, it happened to me the other day...
But your problem is minor. All you have to do is put the alternator belt back on, or maybe get a new one...
Old 08-01-2008, 08:02 AM
civiccoupe94's Avatar
haha this **** is funny but seriously i feel bad for the op.
your timing belt is fine, if it was the t-belt that came off, you might be screwed with some bent valves.
just like what cruiserdude said, your alternator belt came off or snapped. just go to an autoparts store and buy one for 15 bucks.
and stop going 90 mph and blowing tires, breaking belts
Old 08-01-2008, 08:41 AM
Eaglekper0046's Avatar
Default Re: (civiccoupe94)
Some advice. Know what your talking about before you post, so you dont sound stupid. And don't brake the law and admitt it
Old 08-01-2008, 10:39 PM
RIPPO's Avatar
it's just a shitty situation. sorry for the long explanation im a noob to the mechanics. so now i took off the timing belt cover (plastic piece) does the car still have an alternator belt even if i don't have a/c?
Old 08-01-2008, 10:51 PM
blkegcoupe's Avatar
Location: ....................................................................................................
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by srmofo &raquo;</TD></TR><TR><TD CLASS="quote">that sounds more like muffler bearings to me, you might wanna check those </TD></TR></TABLE>thats a mercedes that has muffler bearings
Old 08-02-2008, 05:31 AM
93preludeh22's Avatar
Default Re: (RIPPO)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RIPPO &raquo;</TD></TR><TR><TD CLASS="quote">it's just a shitty situation. sorry for the long explanation im a noob to the mechanics. so now i took off the timing belt cover (plastic piece) does the car still have an alternator belt even if i don't have a/c?
Yes.. You need an alternator belt in order to spin your alternator..
EDIT: Why did you remove the timing belt cover??? Did you read the other posts?
Old 08-02-2008, 05:34 AM
Default Re: (93preludeh22)
Here's a picture of what an alternator looks like. Is this where the belt fell off?
NOTE: Your alternator may not be in front of your engine..
Old 08-02-2008, 05:41 AM
alphalanos's Avatar
Default Re: (RIPPO)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RIPPO &raquo;</TD></TR><TR><TD CLASS="quote"> does the car still have an alternator belt even if i don't have a/c?
</TD></TR></TABLE> LOL ...sorry. a/c belt and alt belt are two separate items. go to autozone and get an alt belt. its like $10.
Old 08-02-2008, 07:31 AM
JoeDel's Avatar
wow, get an alternator belt and if you dont drive it much you should check your tire pressure before getting it up to 90... look it up on google there should be a tutorial somewhere on how to check you tire pressure, take notes,
Old 08-02-2008, 09:52 AM
civicjoe's Avatar
Default Re: timing belt fell off!!! please help!!!! (JoeDel)
well your at it make sure to check your halogen fluid, you wouldn't want your lights overheating!
badassracer's Avatar
some one take his honda away b4 some one gets hurt!.....meaning the honda lol id hate to see him service anything else on the car..
Old 08-03-2008, 06:45 PM
srmofo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by na+b18c_hatch &raquo;</TD></TR><TR><TD CLASS="quote">
no you dummy, mufflers don't have bearings. OP, check your muffler fluid </TD></TR></TABLE>yes they do...
Old 08-03-2008, 06:59 PM
JdelMsolG's Avatar
hahahaha. oh man.
Old 08-11-2008, 02:17 AM
jakeypoo12's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by srmofo &raquo;</TD></TR><TR><TD CLASS="quote">yes they do...</TD></TR></TABLE>
hahah nice pic
Quick Reply: timing belt fell off!!! please help!!!!
