temperature gauge goes to H, not overheating, HELP!
Old 07-26-2005, 01:06 PM
cthan3o3's Avatar
Default temperature gauge goes to H, not overheating, HELP!
everytime i start my car, no matter if its hot or cold, it always jumps beyond the H mark. anyone know what the problem could be? could it be a defective gauge cluster(Stock)? the coolant in the overflow is full, coolant in radiator is full, the fans work, still dunno wtf is going on.
Old 07-26-2005, 01:26 PM
92HatchB16's Avatar
Default Re: temperature gauge goes to H, not overheating, HELP! (cthan3o3)
Did you recently move around your dash or try to do anything to your gauge cluster?? Sound slike maybe it is defective, but it is hard to tell...
Old 07-26-2005, 02:20 PM
cthan3o3's Avatar
Default Re: temperature gauge goes to H, not overheating, HELP! (92HatchB16)
yea i just removed the cluster to put in some amber bulbs. i've taken my cluster out like 4 other times. so u think its a defective cluster?
Old 07-26-2005, 02:53 PM
92HatchB16's Avatar
Yea, sounds like maybe something got moved when you took it out...that happens really easily. I would try to borrow a gauge cluster from someone you know and see if it is ok with another one...I'm sure it is just that cluster if it goes all of the way above the H...Overheating wouldn't spike up like that and stay there...Hope you get it figured out man
Old 07-26-2005, 03:12 PM
harlesjohn's Avatar
if you dont feel like trying to find the defect just get a pyro meter i think there kinda costly though. good luck
Old 07-26-2005, 09:25 PM
cthan3o3's Avatar
Default Re: (hondaharley)
what other problems do u guys think it can be besides the cluster? could it be the thermostat or sending unit?
Old 07-26-2005, 09:37 PM
duggy's Avatar
you probably messed it up doing the amber lights.
Old 07-26-2005, 09:48 PM
rasinhell's Avatar
Default Re: (duggy)
it could be a sensor. the thermostat doesn't do anything except open and close. I think there is a thermosensor(?) or something like that, and it checks the engines temp when u start the car up..
Are you having trouble starting at all? Because if the sensor thinks the motor is really that hot, it'll have trouble starting because it wont give it as much juice as it does when its a cold start. Does it idle low when it starts cold ?
VTEC_Honda
04-14-2010 12:43 AM
JDM_WHR
06-13-2009 11:42 AM
Blue00Si
11-02-2007 07:33 AM
projectTeG
05-10-2004 10:31 PM
Rhetoric
09-14-2001 06:55 PM
Quick Reply: temperature gauge goes to H, not overheating, HELP!
