Swapping 00 B16a2 into 96 Civic hatch - need help
#26
Re: Swapping 00 B16a2 into 96 Civic hatch - need help
Yes they can be "backed up". Just have to put your phone on speaker and have fun with your XBOX. So, what did they say? Like I mention before, it is practical to source a P30 ecu. Look to spend around $200. There's a dude selling his for $500 at the Norcal Marketplace. If you think it's worth it. I'm not advertising for him. I just think he's a b*tch for doing that.
#27
Hey thanks for putting up with my **** and finally I've decided to go k-series. I know what's involved and what I need and the costs. thanks to k20.org I've found out the info I need. So next week I'm picking up the motor and some parts. Pretty soon I'll post up a build thread and a write up w/pics of how to BAR it. So yeah, thanks again!
#28
he can and HAS to run the si ecu. in california the ecu code has to match the engine code if i remember correctly. and the transmission needs to match too i think.
#29
#31
Not 100% sure but couldn't you run 96-98 ex engine harness with stock 96-98 dx cabin harness and just use a obd2a to obd2b jumper harness to hookup the 99-00 si ecu. Well this work? Anybody know??
if u keep ur sock dx radiator then
94-01 gsr for lower radiator hose
94-97 del sol for upper hose
#32
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/faqs-frequently-asked-tech-questions-1998336/
Check out the FAQ thread. It has ton's of helpful info for swaps.
#33
its much easier and cheaper to add vtec to your harness trust me it wasnt worth the 200+ dollars for the ex wiring harness just because it has an extra two plugs
#34
Just keep the ecu obd2a with either a 96-98 gsr ecu or a 96-98 p30 del sol ecu. Add vtec to your wiring harness.
#35
I dont know if you have found a harness but I have a obda2 harness that came off a b18c forsale. So all you would need is a ecu adaptor and you can use your si ecu.
#36
#37
#38
So just stick with a 99-00 p2t si ecu and just mod the harness???
Will this setup throw a cel???
#40
my1stek
21
09-11-2011 04:15 PM
