Swapped Civic Overheating
Old 08-03-2005, 06:50 PM
WakeSpliter's Avatar
Default Swapped Civic Overheating
I have a 98 Civic with 98 JDM B16A SiR-II motor
after my car has been running awhile, i see the temperature guage climb when i am going below 45 MPH unless i have the heat blasting. When i am on the highway, no overheating problems exist. The only way my car won't overheat when i'm cruising through town is if the heat in on full blast.
I search about this in the past on a couple of different forums and everyone says:
-bleed the coolant
-check fan switch
-replace radiator cap
-replace themostat
is it possible that my radiator the has 136,xxx is loosing its efficiency? I mean it was only supposed to be cooling a SOHC D16Y8, so would the B16 overpower it? Or is it one of the things listed above?
Basically, i just wanted to know what course of action you guys think i should take first to resolve this problem. Thanks
Old 08-03-2005, 06:51 PM
A.E Motoring's Avatar
Default Re: Swapped Civic Overheating (WakeSpliter)
try replacing the thermostat
Old 08-04-2005, 04:37 PM
vics_si's Avatar
Default Re: Swapped Civic Overheating (SPNFEDEJ)
try all of your cheapest routes first like replacing thermostat coolant flush just pretty much look over all of your coolant lines and see if you cant find somethin stupid wrong
Old 08-04-2005, 04:47 PM
-Gambit-'s Avatar
Default Re: Swapped Civic Overheating (vics_si)
right after i swapped my car it was doing the same thing. I just had to bleed my coolent. My rad also has 130k on it
Egsirvtec
11
07-23-2018 09:13 PM
bartleby13
12
01-13-2013 12:08 PM
hotcivicsi
11
04-09-2009 06:19 PM
aws140
08-12-2007 09:36 PM
Tomek
05-30-2003 12:39 PM
Quick Reply: Swapped Civic Overheating
