Suspension rattle...yes i searched
Old 07-25-2006, 08:04 PM
brockscivic's Avatar
Default Suspension rattle...yes i searched
Ok, on my 93 EX sedan, it has the wierdest rattle ever. When i drive on rough road or up my gravel drive...its rattles constantly from the drivers side. This rattle goes away when i have the brake pedal depressed. Any ideas? Its starting to **** me off.
And, im tired so my description may be a little vague
Old 07-25-2006, 08:06 PM
tatmark1's Avatar
put car up on jacks and look at it. should be able to find out the problem
Old 07-25-2006, 08:09 PM
Default Re: (tatmark1)
ive actually looked...and the only thing i can come too is this
the center of the brake caliper...the section that holds the pads is loose. Meaning i can pull it back and forth and make a similar rattle.
I was told this play was normal, but none of the other calipers have the looseness to them. Which led me to believe otherwise but i wanted to ask and make sure.
Old 07-26-2006, 05:41 AM
dpkelly's Avatar
Default Re: (brockscivic)
Maybe your upper ball joint. Do you hear a clunking while going over speed bumps? Grab the steering knuckle above the wheel and pull back and forth and see if it moves relative to the upper control arm. Or while it's on jackstands, lift the wheel up and down and look for the same movement.
Old 07-28-2006, 10:28 AM
D3E H22 TYPE SH's Avatar
Default Re: (dpkelly)
yea dood that happends to me too. like when you drive over tought road and **** it rattles and ****. idk if its my suspension but yea hit me bacC when you find out what the solution is to this problem k? thans dood...
Dee
Old 07-28-2006, 10:30 AM
hey wats up dood... um yea i have that suspension thing too like when i go on rought roads and **** my car starts rattling and ****. do you know what the solution to the problem is? hit me bacC iight? thanks...
Dee
Old 07-28-2006, 10:31 AM
philosofy1's Avatar
Default Re: Suspension rattle...yes i searched (brockscivic)
is your car lowered? i know i had a sleeve loose on my coilover and that used to happen to me as well.
Old 07-30-2006, 01:44 PM
Default Re: Suspension rattle...yes i searched (philosofy1)
yea my car is lowered... i have coilovers. but yea what can i do to fix it? hit me back asap k? thanks bro...
Dee
Old 07-30-2006, 02:33 PM
slo93si's Avatar
Make sure all of your bolts are tightened down on your shock tower. Check the top and bottom. I had a friend with this problem after we put is suspension on. It did that for a few days before we looked at it. The bolts at the top of the shock tower were coming loose. Tightened them down and no more ratteling.
bnuk013
02-08-2008 02:23 PM
hondaless
12-19-2005 12:31 PM
rice_classic
05-23-2004 11:59 AM
E-Rok
01-18-2004 03:51 PM
Spade
06-20-2002 07:43 AM
Quick Reply: Suspension rattle...yes i searched
