starting car without the key
My car was recently stolen and the theives broke the ignition. I dont want to spend a grip load of $ for a new ignition switch. I was wondering if i can get the s2000 push start button...wire it somehow so i wont need to use the key? btw...i dont want to buy a used ignition switch..cause i dont want to have 2 different keys...1 for ignition and 1 for doors/trunk. Any help would be appreciate. Thanks.
Re: starting car without the key (DeliveryM2n)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DeliveryM2n »</TD></TR><TR><TD CLASS="quote">My car was recently stolen and the theives broke the ignition. I dont want to spend a grip load of $ for a new ignition switch. I was wondering if i can get the s2000 push start button...wire it somehow so i wont need to use the key? btw...i dont want to buy a used ignition switch..cause i dont want to have 2 different keys...1 for ignition and 1 for doors/trunk. Any help would be appreciate. Thanks.</TD></TR></TABLE>
so your car can be stolen at the push of a button??
Re: (pdiggitydogg)
an S2000 still uses a key, but instead of turning it that last bit of rotation to engage power to the starter, the "start" button does that...... I am sure you could rig it some how and use any kind of button you wanted... but why???
Re: starting car without the key (1993sir)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1993sir »</TD></TR><TR><TD CLASS="quote">stick a your car key or a screwdriver or whatever fits into the white piece and turn it like you would the key in the ignition and the car will turn on. to answer your question and not give a smart remark</TD></TR></TABLE>
NJ huh? haha, jk..
NJ huh? haha, jk..
Re: starting car without the key (Limited S.L.I.P.)
the S2000 push button still utilizes the key
just not the last "click" we use
just make it even more easier for a theif
get a used ignition switch, but you can swap out your key tumbler if its not broken....if it is, get the 3 other tumblers and swap em in, so u have one key
very easy, just click it 2 the second or 3rd position, and theres a little pin that you have to push in, it will slide right out once the pin is depressed...oh yeah, theres also a star screw that has to come out, but i just put vice grips around the bolt and took it out that way, cause i didnt have a bit that looked anything like that
Note my pin got caught on something on the way out so it needed a lil force, but other then that its very easy
Re: starting car without the key (Slammed Si)
when my car was stolen they broke the whole thing off. my cousin just zip tied it eventually im goin to have to either replace it or have someone weld it back together.
wizzards581
12
12-11-2003 06:25 PM
