spark plugs will NOT come out...can figure it out.
Old 05-06-2009, 08:36 PM
  #51
1nsoman1ac's Avatar
Default Re: spark plugs will NOT come out...can figure it out.
hahahaha ftw lmao. alright. pb blaster it is. and a better ratchet. lol.
cocolate and penut butter are the best sandwiches.
Old 05-06-2009, 08:47 PM
  #52
Sol to Sol
JarvisW's Avatar
Oh, and if you have an impact gun or wrench, put it on low psi, and it can kinda knock it loose. Once again too much torque will be very bad for your head. But low pressure vibrations will help the PB penetrate.
Or, just soak it with PB, it may take a couple days, but it will eventually work its way thru.
Old 05-06-2009, 08:52 PM
  #53
6footmidget's Avatar
hmm i dont understand why people said let it warm up, metal gets warm and expands and it will be tighter, and if it wont budge then youll strip it because if you look at other bolts that wont move and you give it too much force, your tool will slip and strip it then youre stuck with a spark plug in your motor, but i dont have advice on what to do, just telling you what not to do :]
Old 05-06-2009, 09:10 PM
  #54
1nsoman1ac's Avatar
good info jarvis..keep it comin'. thats what she said hahaha lamo. wow. im so dumb.
and 6footmidget...any advice is bettetr than none! thank you
Old 05-06-2009, 09:16 PM
  #55
Sol to Sol
JarvisW's Avatar
Well, thats all I got. Shot the load. lol.
Like I said, and you can do this by hand with a rubber mallet and a ratchet. Tappin the ratchet while holding it tight can make some vibrations. But really, thats hazardous too. An impact gun on low PSI will do that with no risk of twistin it or your hands in weird ways lol. It could also bust it loose. But I wouldn't use it on the setting they use to take Lug Nuts off with, but a nice 2-3 beats a sec (instead of 30 or so lol)( you can kinda feel whats right) will help it loosen.
Worst comes to worse, you can remove the head, flip it over, and PB the underside! lol
Kidding, it will work eventually.
Old 05-06-2009, 11:19 PM
  #56
waaBAAH's Avatar
i know impact guns and what they accomplish.. but in this case i would advise against it.
breaker bar/cheater bar is really the only option if you really wnat the plugs out.
like someone said earlier.. gms and some new model fords (gm's being the worst) actually have TSB's on plugs breaking in the head. i have fallen victim to some of these cars. if i recall correctly they do call for some sort of penetrating oil and working of the plug back and forth and of course it is always the hardest to reach one and never the plug up close easilly accessible. lol
i cant picture all four being stuck like this. use more force.
Old 05-07-2009, 05:41 PM
  #57
1nsoman1ac's Avatar
wow...so i sprayed some pb in there today at aorund 12...then came home at 8, took the lug wrench from a 92 camero, shoved the end of the ratchet in the ukin hole in the end of the wrench and guess what? pulled the dam plugs out.....didnt strip anything....cylinder 3 and 4 made this wawful sound as metal scraped on metal lol and i was liek oh **** lol. but when i took out, they were thread free...
thank you all for all the advice.
Old 05-07-2009, 05:50 PM
  #58
TravisCadello's Avatar
ya, that noise you hear i always hear. even if i don't tighten them that much. So how did the plugs look?
Old 05-07-2009, 05:52 PM
  #59
1nsoman1ac's Avatar
well i couldnt tell...the pb blaster soaked the hell out of them...so anythign bad on them dissolved
or was lubed up to the point where they were all black...i mena there definatley was black ****...but like i know its from everyday driving.
Old 05-07-2009, 09:48 PM
  #60
Dangousity's Avatar
You can also tighten the plug 1 degree then remove the plug, it helps if the the steel and alum did fuse. Trust me in helicopters you have alot of alum/steel bonding bolts
Old 05-07-2009, 10:26 PM
  #61
gotz2b16's Avatar
take it to a shop and let them **** it up so you can have them fix it for next to nothing.. =]
Old 05-07-2009, 10:54 PM
  #62
waaBAAH's Avatar
OP already took them out. lol
good job man... so for future reference...
HIT IT WITH YOUR PURSE!!! lol
Old 05-07-2009, 10:57 PM
  #63
gotz2b16's Avatar
One problem tho..
YOU HAVE NO Vrrrrrrrrroooo-VVVVEEEEETAAAAAAAAKKKKK!!! lol!
Old 05-08-2009, 02:07 PM
  #64
1nsoman1ac's Avatar
lmao i will definately remember that. "hit it with your purse"...hahahahaha still makes me laugh. how do you do those signature things where people post quotes and **** at the bottom of their posts? cuz im gonna it mine lol.
One problem tho..
and i have another problem..... B sixteeennn aaaaaaaaaaaaaaaa head coming in the mail. lol. im thinking the b16A top and b18b bottom end will be a decent upgrade. but idk. what do you guys think? and how much work is there involved in making the b16a fit? i heard somethign about someting having to be removed from the block to create the port for oil flow and somehting adding on to it?
Old 05-08-2009, 10:09 PM
  #65
Sol to Sol
JarvisW's Avatar
Hey great you got them out. Squeeks I wouldn't have been worried too much about. It means its moving. When I lost my head, it didnt make any noise, it just kinda snapped loose!
I would still advise against too much torque, but, with Honda motors so cheap, I guess I shouldn't worry so much.
Old 05-09-2009, 03:34 PM
  #66
Pothole987's Avatar
Excellent news you got them free. make sure you check the gap and clean them good, and put antisieze on them so you don't have to go through this again.
Old 05-12-2009, 05:54 AM
  #67
ricoshademan's Avatar
definately an airflow problem
Old 05-12-2009, 06:05 AM
  #68
JKov240's Avatar
Unless the shop you're taking it to is half-retarded, they won't touch it once they realize that the spark plugs are seized up.
Old 05-31-2009, 08:25 AM
  #69
bsivoljr's Avatar
Originally Posted by 1nsoman1ac
wtf? a purse?
whats a cheater pipe?
thank you for the first piece of actual good advice.
well i dont give a **** if the damn ratchet breaks. im not weak...i work in a warehouse liftin heavy **** all day long till i feel liek my spines about to come out my ***. im not boasting or anything, im just saying i can give a ratchet a decent ****ing tug. so if i get a bigger ratchet...i wouldnt strip the aluminum head threads?
^^^LMFAO SPINAL
Old 05-31-2009, 09:10 AM
  #70
98civtec's Avatar
use an impact wrench that would work lol
Old 05-31-2009, 09:11 AM
  #71
thumper64's Avatar
and if you let the motor warm up then everything is bigger.. even the spark plugs will expand. so in theory you are then trying to remove a tighter spark plug.
Expansion coefficients. Different metals expand at different rates and different amounts. Example, your valve guides are bronze (I think) and the head is aluminum. Try to smack the guides out with the head cold and you damage the head, but heat the head up and the guides will press out without inflicting damage.
EDIT: Definitely a reason to use antiseize.
AcuraIntegra_19_94
01-22-2009 06:14 PM
8lkgsr
08-12-2007 12:47 AM
streetsweaper
13
10-03-2005 05:36 PM
krazn
12
11-22-2002 08:36 PM
Quick Reply: spark plugs will NOT come out...can figure it out.
