SOME AIR NOISE INSIDE BEHIND ME WHILE DRIVING
Old 04-05-2005, 07:00 PM
BadEH2's Avatar
Default SOME AIR NOISE INSIDE BEHIND ME WHILE DRIVING
hey guys, dude, so i have this problem in the rear section of my interior, Im hearing this frickin NOISE all behind me, its REALLY REALLY LOUD... It sounds like u can hear my tires spinning from the inside of my car while im driving...Sounds like im in an airplane... all of my friends that ride in the car are like " holy **** wat is that noise!??! sounds like im in a airplane", lol. im thinking the vibration from the wheels is going through something and like going through something and comin into my interior... it is weird... when i stop.. its gone.. wen i go, its starts to make that noise again... when i start to brake... the noise lessens... the faster i go, the louder...
Old 04-05-2005, 07:09 PM
EGCivicCoupe's Avatar
Honestly I think its your tires. Not sure why but does it do it on all roads? I find that on this one road I hear that sound alot its very weird. I think its the tires you are hearing but then again I haven't heard it.
Old 04-05-2005, 07:31 PM
BadEH2's Avatar
Default Re: (EGCivicCoupe)
could it be the springs? i got sprint springs... um... it cannot be my tired i dont think...
Old 04-05-2005, 08:37 PM
Do_Ster's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EGCivicCoupe &raquo;</TD></TR><TR><TD CLASS="quote">Honestly I think its your tires. Not sure why but does it do it on all roads? I find that on this one road I hear that sound alot its very weird. I think its the tires you are hearing but then again I haven't heard it. </TD></TR></TABLE>
yeah it might be your tires. get them balanced and that might fix the problem. i don't think it would be your springs though
Old 04-06-2005, 02:10 AM
s2kdre's Avatar
Default Re: (_OEM_)
wheel bearings maybe.
Old 04-06-2005, 04:10 AM
RoadconeTuning's Avatar
what kind of tires do you have??? if you just put springs on did you get it aligned like your supposed to??? if not then its your tires out of camber AND toe and if i tires outta toe it will get pretty damn loud. even more so if they are sticky tires.
Old 04-06-2005, 12:59 PM
BadEH2's Avatar
Default Re: (Dude29662)
i have some fresh michelins 195/55/15, some si's. i recently got some springs...(spring springs) but it doesnt EVEN LOWER IT THAT MUCH THOUGH.. should i still get it aligned and balanced?? what about those WHEEL WEIGHT things..??
Old 04-06-2005, 01:02 PM
jlacoy82's Avatar
Default Re: (BadEH2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BadEH2 &raquo;</TD></TR><TR><TD CLASS="quote">i have some fresh michelins 195/55/15, some si's. i recently got some springs...(spring springs) but it doesnt EVEN LOWER IT THAT MUCH THOUGH.. should i still get it aligned and balanced?? what about those WHEEL WEIGHT things..??</TD></TR></TABLE>
When they mounted the tires, they SHOULD have balanced them, but whos to say though. If you still have the receipt for the tire mounting, it should say on there.
Old 04-06-2005, 01:03 PM
Unceasing Measure
Archidictus's Avatar
Default Re: (jdmhonda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmhonda &raquo;</TD></TR><TR><TD CLASS="quote">wheel bearings maybe.</TD></TR></TABLE>
This is my guess. Can you describe the pitch and behavior of the noise a little better?
Old 04-06-2005, 05:43 PM
BadEH2's Avatar
Default Re: (Archidictus)
the noise is like... riding in a airplane... its like wen ur outside on a really windy day, and wind is blowing all in ur ear n ****.. hard to explain. like a deep KUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUU
Old 04-06-2005, 06:47 PM
matto23's Avatar
hit any curbs lately?? if so, I am guessing your trailing arm is bent.
or your alignment is off. or you tires have uneven wear
Old 04-06-2005, 07:09 PM
Couldn't be your tire pressure could it?
Yea I have Potenza S0-3 205/50/15 on SI's .. (Maybe its just the SI's ;-) lol ) and it only makes that sound on one road in town, its awkward. The first time I heard it I pulled over and checked all my tires.
Old 04-06-2005, 07:24 PM
matto23's Avatar
yeah, i also know of a couple roads that will cause such a noise. its pretty scary. I have also been tempted to pull over and check for tire pressure.
Old 04-06-2005, 09:49 PM
jdmkevin's Avatar
Default Re: SOME AIR NOISE INSIDE BEHIND ME WHILE DRIVING (BadEH2)
Are your back seats taken out? If you don't have a back interior it could be way louder than normal. (Especially if the small fuel pump cover is removed.) If not, then yeah I'd say get your tires balanced or wheel bearings.
Old 04-06-2005, 11:59 PM
eg4usdm's Avatar
is your camber off? maybe your rubbing against the fender wall....my guess..
Old 04-07-2005, 04:53 AM
BadEH2's Avatar
Default Re: (eg4usdm)
my interior is still all in... im gonna get it checked today, im guessing my wheel bearing or i need to balance them. My tires arent wearing, they are still fine and hav a lot of life left..
Old 04-07-2005, 09:42 AM
oinkus's Avatar
what kinda tires are you rollin on .....
Old 04-07-2005, 10:15 AM
Sick_Hatch's Avatar
when you turn your wheel right or left does the noise get louder on one side and stop or get quiet on the other? I had this problem in my Del Sol this year, and it was my rear wheel bearing. Same **** about it gettin louder and louder the faster you go. Look into the bearing, i really think thats your problem.
Old 04-07-2005, 11:00 AM
RaYnE's Avatar
i had that exact problem on my DA..turned out to be the wheel bearing.
Old 04-08-2005, 02:49 PM
BadEH2's Avatar
Default Re: (Sick_Hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sick_Hatch &raquo;</TD></TR><TR><TD CLASS="quote">when you turn your wheel right or left does the noise get louder on one side and stop or get quiet on the other? I had this problem in my Del Sol this year, and it was my rear wheel bearing. Same **** about it gettin louder and louder the faster you go. Look into the bearing, i really think thats your problem.</TD></TR></TABLE>
YES!!!!!!!!!! THERE IS THE ANSWER I WAS LOOKING FOR!!!!!!! U GOT THAT **** MAN, DUDE, WHEN IM GOING AROUND LIKE 45 and SWITCH LANES OR SOMETHING, THAT **** GETS LOUDDDERRR, and WEN I MAKE TURNS IT GETS REALLLLL LOUD.... dude, thank you godddd!! lol, i finally know what it is.. HONDA TECH IS A LIFE SAVER
EDIT: HOW MUCH DID IT COST YOU, SICK HATCH?? and was it easy?
Old 04-08-2005, 02:56 PM
kingkong's Avatar
coool man
Old 04-08-2005, 03:40 PM
BadEH2's Avatar
Default Re: (kingkong)
ok so i searched... it costs about 80-100 for the HUB and the bearings... cant i just buy the bearings and replace it myself.. b/c i take auto tech class at school(im a junior in high school) and my teacher most likely know what the hell he is doing so, im just wondering, do i have to replace the whole HUB of my rear drum brakes? or can i just buy the bearings?
Old 04-08-2005, 03:55 PM
Help we my pennies
BLUE EH3's Avatar
wat car?
Old 04-08-2005, 04:02 PM
BadEH2's Avatar
Default Re: (BLUE EH3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BLUE EH3 &raquo;</TD></TR><TR><TD CLASS="quote">wat car?</TD></TR></TABLE>
1994 DX HATCH...
Old 04-08-2005, 04:13 PM
Sick_Hatch's Avatar
it cost me 80 for the hub and bearing and a friend of mine did it for me in less than an hour. You wont save much just getting the bearing, he also told me it is better to get both the hub and bearing. He's a Honda Technician so I took his word for it. Btw I have had rear discs, so I dont know how much of a difference that makes for you. Good luck
Quick Reply: SOME AIR NOISE INSIDE BEHIND ME WHILE DRIVING
