sleeved block??
Old 06-26-2003, 07:34 PM
hbvetteslayer's Avatar
Default sleeved block??
what is a sleeved block??
Old 06-26-2003, 07:45 PM
ExospeedAMcrx's Avatar
Default Re: sleeved block?? (hbvetteslayer)
well what comes to mind are Resleeved blocks. Which are blocks that have the sleeves cut and replaced with a stronger/thicker type of sleeve that are pressed in.
here is a sample of the Type of sleeve that replaces the stock sleeves.
and a block with the Sleeves installed.
Here is a block with stock sleeves.
The sleeves are used for strengtening the block and it also gives the option of Boring the block bigger than the stock specs.
Old 06-26-2003, 07:46 PM
t0p_sh0tta's Avatar
Sleeving: Replacing the piston sleeves with a thicker/stronger material for extra strength. Usually associated with high compression or FI motors.
Old 06-26-2003, 08:40 PM
Mr. Badwrench
boostedcivicsir's Avatar
Default Re: sleeved block?? (t0p_sh0tta)
there are a few styles also.
they are made of ductile iron usually.
there are t sleeves
closed dec sleeves, and the inserts you have posted up there.
Old 06-26-2003, 08:51 PM
b18c1guy's Avatar
thats it
Old 06-26-2003, 08:56 PM
Default Re: sleeved block?? (boostedcivicsir)
woops.. ya i forgot there are Closed deck sleeves, T sleeves..
I have some other pics of those type of sleeves that we have done.. but not prepped for Forum Upload as of now..
dc2_poojan
06-08-2012 07:02 AM
cotten_itr
08-19-2007 01:21 PM
lsgsrhatch23
06-20-2006 07:05 PM
cbmprelude
10
09-07-2004 05:10 PM
satan_srv
03-19-2003 01:52 PM
Quick Reply: sleeved block??
