a/c intermittent problem 95 civic
Old 05-03-2015, 01:07 PM
Honda_San's Avatar
Default a/c intermittent problem 95 civic
Hello HT,
I have tried searching this issue but cannot seem to find a thread that has ended with a solution to any similar problem.
I have a 95 civic ex coupe. I have been having an issue with the a/c in this car. What happens is this: when the car has been allowed to sit in the sun for a while and get the interior good and hot, the a/c does not engage. This is to say the compressor clutch nor the condenser fan cut on. I have charged the system with the correct amount of refrigerant with the machine we have at work. It has not leaked out. If the interior of the car is allowed to cool off, the a/c will start working and usually keep working. Every now and then it may cut back off, but this really seems to be happening with the interior being hot.
I have already replaced the climate control, tried swapping a/c compressor clutch and condenser fan relays around, as well as substituting a new one in, and replaced the climate control harness from the control itself down to where it plugs in behind the cigarette lighter to the rest of the body harness. Also the blower motor resistor.
I have tested continuity at the relay with the a/c button on and the system not operating and I am getting no signal at the relay when the a/c is not wanting to work. Keep in mind that when I press the a/c button on the climate control I am always getting the green light indicating the button is pressed. This seems strange to me as I am "magically" getting that signal when the interior cools down. I have tested voltage at the a/c thermostat behind the glove box and I have voltage at pins 1 and 3. If I ground pin 2, the a/c will come on and function as it should.
Any help would be appreciated. Sorry if this post sounds choppy at all, but I am becoming pretty frustrated with this issue as I cannot understand what is making it come on and work fine and then not work at all when I need it most! Thanks in advance!
Old 05-03-2015, 01:26 PM
Honda_San's Avatar
Default Re: a/c intermittent problem 95 civic
I have followed the following flow chart:
Fuses 13 and 35 are ok.
The place I ended up at the flow chart was to replace the heater fan switch. I am assuming I did this in putting in another climate control?
Old 05-03-2015, 01:39 PM
Former User's Avatar
Which relay? Continuity between which terminals? What do you mean by "signal"?
When the A/C button didn't work to turn on the A/C?
Not sure what you mean here.
Old 05-03-2015, 01:42 PM
Did you do ALL tests in the flowchart when the A/C button didn't work to turn on the A/C?
Old 05-03-2015, 02:00 PM
#1 Super Guy
94eg!'s Avatar
You probably won't be able to test for the problem unless the components are 120 degrees or more.
My 94 CX does the same thing. I think it's a bad solder joint behind the AC button. I found if I popped off the AC-button cover and jammed the pointy end of a wooden kabob skewer into the hole, it worked again. I stick it in above the circuit board and it presses down on it slightly. Then the compressor kicks on again. I was planning on either taking the unit apart & re-soldering all the connections, or buying a new heater control unit. For now I just keep the 2" pointy end of the skewer in my ash tray for when I want AC.
Old 05-03-2015, 02:06 PM
Honda_San's Avatar
The compressor clutch relay. I tested for the a/c request signal and that was not present when the a/c button on the climate control had been pressed.
Yes
I meant that I get an a/c request signal when the interior has cooled off but not when its hot. "magically" was my frustration showing haha!
When I ground pin 2 on the a/c thermostat the a/c will come on regardless of the button on the climate control being pressed.
Old 05-03-2015, 02:07 PM
#1 Super Guy
94eg!'s Avatar
The problem is the signal getting to the relay. The light on the button has it's own ground. This means the signal path & light path are independent. The light being on means nothing in relation to the signal.
Old 05-03-2015, 02:08 PM
Honda_San's Avatar
Now that I went back and read it I need to test the a/c button 22-15. I will get on IN and pull that one up now
Old 05-03-2015, 02:09 PM
Honda_San's Avatar
Yes this seems to be what the problem is. I'm guessing it may be likely that both of my climate control units are bad. It seems like once the components start cooling off I can move the 16 pin green connector around at the climate control and the a/c will come on and work normally, as long as I hold it in the right position.
Old 05-03-2015, 02:15 PM
I would try this^ first.
Old 05-03-2015, 02:17 PM
Honda_San's Avatar
I'll get started taking it apart now
Old 05-03-2015, 02:24 PM
So what exactly did you test for? On which relay pin or wire?
How do you define signal? What's the test and on what wire or pin?
This^ is normal. What was the result when the A/C button didn't work to turn on the A/C?
Old 05-03-2015, 02:25 PM
Not sure what test you're talking about here.
mjsotelo91
07-24-2011 06:34 AM
noboost1
10-02-2010 05:56 PM
GuNnErGoD
07-28-2008 06:47 PM
ob1coby
10-05-2007 05:55 PM
Quick Reply: a/c intermittent problem 95 civic
