Shutter idle 99 lx civic
Old 03-20-2017, 08:15 AM
Sergio Ruiz's Avatar
Default Shutter idle 99 lx civic
I have a 99 lx civic. I have done a full tune up from spark plugs to dis rotor. Fuel system treatment and pcv valve and fuel filter. I also cleaned the iacv. I noticed prob after a months after I did all that the car had this weird shutter at idle. Like a misfire. It wouldn't due or anything serious but when warmed up and idle at stop light it would shutter every 30 sec to a minute. Not sure if anyone has had the same issue plz get back to me. Oh and also it runs perfectly fine while driving only at idle it happens.
Old 03-20-2017, 03:18 PM
mk378's Avatar
Default Re: Shutter idle 99 lx civic
Check / adjust the valves.
Old 03-20-2017, 09:06 PM
Previous owner had already done it plus I don't hear any ticking from head. Sounds quiet. It just barley started doing it 6 months after owning it. I read that the distributor could be going bad. How do I go about checking it.
Old 03-21-2017, 03:36 AM
Jimi Hondrix's Avatar
How many miles ago?
Doesn't indicate wether or not the valves are adjusted correctly
Read this: Part 1 -How to Test the Igniter, Ignition Coil Accord, Civic, CRV, and Odyssey (pages 1-5)
Do a power balance (drop) test. Instead of pulling spark plug wires ..pull fuel injector connectors one at time and listen for idle to drop or stay the same. If it stays the same there is an issue. Check ignition timing with timing light.
Try turning headlights or a/c on while it's idling and see if it does what you described initiially.
VersedCivic
05-19-2014 05:23 PM
twisted civic
07-19-2008 11:09 AM
Sprayonsumadidas
09-22-2005 08:18 PM
matt_in_sd
02-06-2005 11:58 PM
cruisemo
08-07-2002 02:40 PM
Quick Reply: Shutter idle 99 lx civic
