Should I change Manual Trans Fluid?
Old 06-01-2014, 07:24 PM
Bavarian330's Avatar
Default Should I change Manual Trans Fluid?
Hello,
over the weekend I picked up a 98 Civic Ex with a manual gear box. The car has 124k and is extremely clean all things considering. This morning, I changed the oil/filter with Royal Purple synthetic etc. and added some Lucas fuel injector cleaner in the tank. Next weekend I will flush the cooling system and tackle the manual trans fluid change. However, I have no prior service history, am I flipping a coin with the transmission health by changing the fluid at 124k? Also, if I get the green light from the forum, what would be a high quality trans fluid to use?
Best,
Justin
Old 06-01-2014, 07:26 PM
Default Re: Should I change Manual Trans Fluid?
Also, any particular coolant I should use?
Old 06-01-2014, 07:30 PM
Fnix's Avatar
It wouldnt hurt. I use Honda OEM Trans fluid and diluted prestone coolant. If you live in a warmer climate and track your car you can use distilled water instead of coolant.
Old 06-01-2014, 07:33 PM
Ok, I was just making sure because I know there is a general rule of thumb that if you haven't change the trans fluid after 100k....you should just leave it...because it can cause significant damage to the transmission
Old 06-01-2014, 07:40 PM
the171's Avatar
oem mtf is perfectly good. redline makes a nice mtf also. have heard good things about torco fluid but haven't tried it. As for coolant... i don't think its quite as drastic a choice... any 50/50 mix has worked for me.
Old 06-01-2014, 07:42 PM
shotoutacc0rd's Avatar
IV heard this before about autos but IV never hear it for manuals. Personally I think its just that people use crap fluid, which will hurt the transmission.
try GM synchromesh
Old 06-01-2014, 08:35 PM
nub
nub's Avatar
New to you, used vehicle with no service records. Go through every maintenance item as your budget allows. This way you know where you stand and can start regular service intervals for everything. The timing belt and associated items should be a priority if previous service is unknown at your mialage.
To your trans fluid question...regular 10W-30 NON synthetic motor oil, GM Syncromesh is a good mix.
Don't use the currently available Honda MTF. It's thin as water and better suited for newer transmissions, not to mention it's overpriced.
Old 06-02-2014, 03:56 AM
Cool Cool Island Breezes. BOY-EE
B serious's Avatar
No, you're not going go hurt a MANUAL trans by changing fluid that hasn't been changed in a long time. This rule only applies to auto transmissions...and even then only applies to actual flushes....not drain and fills.
Honda MTF is neither too thin nor overpriced. Amazon has bottles for $7.75 shipped (if you have amazon prime). Otherwise, dealers sell it for about $9/qt. You need 2qts (around 1.5-1.75 go in the trans).
Torco MTF also works well. I started using this on cars that I track. I really like the hot temp performance. You'll probably never see those temps on the street though.
Some people like 10W30 non synthetic, but I feel like the trans shifts like **** when it's cold.
Honda OEM coolant is what I use. Or prestone 50/50 if immediate availability is an issue. Don't use tap water if you're going to try to flush the cooling system.
Old 06-02-2014, 09:50 AM
Thanks everyone and B serious, that was exactly what I was looking for. I will pick up Coolant and MTF fluid from the dealership and do both jobs this weekend. I will let everyone know how it goes! After that, brakes & power steering fluid and I think thats it for fluid refresh.
Best,
Justin
Old 06-02-2014, 09:53 AM
Best,
Justin
are you kidding? You're forgetting windshield washer and blinker fluid
Last edited by TomCat39; 06-02-2014 at 06:06 PM. Reason: Kicks acc0rd for Blinker Fluid!
Old 06-02-2014, 12:16 PM
B serious's Avatar
Just make sure the power steering fluid comes from the dealer or you're going to have huge problems.
If you're buying dealer coolant, wait to put it in until you change your t belt/water pump and thermostat. That coolant is a little spendy...but it's good stuff. Might as well not do the job twice.
Old 06-02-2014, 02:09 PM
Basically, everyone should be sourced through the dealer with the exception of brake fluid and engine oil where you can find higher grade oils for the vehicle...
Old 06-02-2014, 03:11 PM
B serious's Avatar
^Yeah, that's kind of how I roll.
Old 06-02-2014, 06:02 PM
Hysterically Calm
TomCat39's Avatar
From the tranny experts I've spoken too the Honda MTF is not as good as it used to be for our older cars. It's now formulated for the newer tranmissions and is considered "acceptable" for the older manuals. Doesn't mean it's the best any more just acceptable.
Torco MTF is touted best out there for street use in our older transmissions while Torco RTF is what is touted as the track fluid of choice.
Many street users tout Redline but I haven't seen it recommended by tranny rebuilders unlike Torco.
From the rebuilders it's either non synthetic 10w30 or Tocro MTF.
GM/Penzoil Synchromesh with Molyslip MT additive is supposedly good but I don't like how it shifts when cold. Still driving on it and it hasn't killed my tranny yet but can't say it's as nice. Winter time it sucks too for shifting into 1st while moving until warm.
Old 06-02-2014, 06:19 PM
B serious's Avatar
I keep hearing about how Honda MTF is too thin and not meant for older transmissions. Idk...I've had no issues using it in my ITR, GSR, EM1, AP1, TSX, AP2, FG2, BB6, EJ8, or any other old or new honda I've used it in. I've even used it on cars that I've heavily tracked.
Torco MTF is great stuff though. I'm not sure it's needed for a street driven D series....but it couldn't hurt. I bought a case of 12 on amazon for $110. Small quantity price is about $15/bottle.
I use RGO in my diff (S2000). Also very good stuff. But I can't bring myself to use it in my trans....even for track use.
Old 06-02-2014, 09:27 PM
Hysterically Calm
TomCat39's Avatar
Yeah, not really sure. I've heard it doesn't protect as well once hot like it used to. Older formulas of Honda MTF provided better hot protection. Worked well in my tranny with Molyslip but who's to say if the wear was a little heavier. Maybe instead of 20 years before rebuild it only lasts 15.... Not like I'm ever going to know the difference.
Old 06-03-2014, 04:49 AM
Fish Twig
tony_2018's Avatar
Are you sure its not 5w30, manual states you can use 5w30 if mtf could not be source. I would assume synthetic would best be used for tranny but now thinking about the abuse it takes on more than the engine maybe a non-synthetic would do the job.
Old 06-03-2014, 05:28 AM
Hysterically Calm
TomCat39's Avatar
Yeah I'm sure it's 10w30 conventional oil that is recommended by the rebuilders while the manual says 5w30. Doesn't the manual imply 5w30 as a temporary solution? I think 10w30 conventional is considered a solid replacement for MTF. I guess it has all the characteristics that older Honda MTF had before it was changed to it's latest formula so can be used for a full service interval.
Also for some reason full synthetic is harder on the synchros so I guess it causes faster wear. I suspect it has to do with less additive package to synthetic over conventional. Conventional is full off additives to meet certain specs while synthetic meets those specs by engineered oil molecules. I'm willing to bet it's the additives that helps protect the synchros better.
Old 06-03-2014, 05:44 AM
Fish Twig
tony_2018's Avatar
Yes, 5w30 is a temp solution.
Old 06-03-2014, 06:07 AM
B serious's Avatar
I'm going to guess that Honda MTF is some sort of synthetic lightweight oil with zinc and other additives...as well as tons of friction modifier. It's made by Idemitsu.
Old 06-03-2014, 09:17 AM
Fish Twig
tony_2018's Avatar
I've used it will no ill effects but if you're tracking or abusing it day to day than I suggest something more on the perfomance line.
Old 06-03-2014, 10:04 AM
ej6fade's Avatar
I would change the fluid regardless, easy job and shouldn't take more than 15-20 minutes tops. Amsoil Manual Synchromesh Transmission fluid is all I use, and I'd swear by it. I currently have a used 92 ex trans mated to my zc, when I got it (was low on cash at the time and needed a trans asap, cost $100) slight grind in second and third, didn't feel or shift that great, with Amsoil it is smooth as butter, shifts perfect, much smoother than the oem mtf. I don't track my mileage, I just change it once a year.
Old 06-03-2014, 02:23 PM
Fish Twig
tony_2018's Avatar
Thats what you call a band-aid, and luckily its still holding on.
Old 06-04-2014, 01:52 AM
ej6fade's Avatar
Thank you for telling me what I already know. Amsoil still makes great products
Old 06-04-2014, 02:50 AM
longest project ever
lostforawhile's Avatar
Location: on the south side of dixie, 1986 Accord Hatch
there are two kinds of Honda MTF now use the early one, or syncromesh
jmanuel
04-24-2014 09:48 PM
Bryanb
02-12-2014 09:48 AM
TL1000R
Honda S2000
01-31-2006 08:24 PM
92integraVTECgsr
07-30-2005 02:49 PM
Cypher0117
05-03-2005 06:47 PM
Quick Reply: Should I change Manual Trans Fluid?
