Shorted out cig lighter and more
Old 02-15-2017, 06:25 PM
mattbatson's Avatar
Default Shorted out cig lighter and more
so the cigarette lighter and climate control ***** and blower fan and fuel gauge are all not working after I attempted to set the timing by using a paper clip to short across two wires on what appeared to be the proper test plug up under passenger side footwell
the car was idling while I was fiddling with the plug and paper clip and blower fan was on high (cold out)
when it sparked thr blower motor shut off
i see the blower fan 40 amp fuse under the hood...but hard to tell if its burned out...and advanced auto doesn't seem to carry it
but the cig lighter and fuel gauge are also not working
where to get that 40 amp fuse?
oh, it is a 1999 Civic ex
Old 02-15-2017, 06:42 PM
civic402lx's Avatar
Default Re: Shorted out cig lighter and more
Your local Honda dealership. EBay.. Amazon.
junkyard..
Seriously? You can't tell if its blown. Did you not remove the fuse to inspect?
You need to check every single fuse in both fuse box. There may be one or more fuse blown.
Old 02-15-2017, 06:59 PM
mattbatson's Avatar
Got it
it was the little 7.5 amp fuse under dash
blower motor working now
ill inspect other fuses tomorrow
Old 02-15-2017, 07:03 PM
jonsey1886's Avatar
Just FYI....insert the jumper wire/paperclip with the KEY OUT OF THE IGNITION!
Old 02-16-2017, 05:56 AM
mk378's Avatar
Clearly, you used the wrong plug. It is safe to jump the ECU test plug at any time, though I think you are supposed to turn the engine off and re-start it with the plug already jumped before setting the timing.
Check the car schematic and go by the wire colors on the plug.
Old 02-16-2017, 06:49 AM
talks to himself
CX-Adam's Avatar
Service connector wires are Brown and Black.
Insert the paper clip with the engine off.
Then, turn the engine on.
Let the engine warm up before attempting to time it. You can hold it at about 3000 RPM until it warms up.
Check the timing with NO ADDITIONAL Load (no headlights, no blower fan, no rear defrogger, and no AC)
For D-series
M/T 12*+-2* BTDC (Red) during idle at neutral
A/T 12*+-2* BTDC (Red) during idle in N or P
for B-series
M/T 16*+-2* BTDC (Red) during idle at neutral
demiseraph
08-05-2011 05:12 PM
Lambo123
01-09-2009 11:25 AM
Crooner
Acura TL, RL & ZDX
10-22-2008 08:51 AM
JDM.Jay
Audio / Security / Video
01-04-2006 03:05 PM
Bucktown
03-08-2004 06:11 PM
Quick Reply: Shorted out cig lighter and more
