shaved head question..
Old 01-13-2010, 08:46 AM
SLOWAUTOEX's Avatar
Default shaved head question..
I have a D16y8 head that has been shaved...I bought it like that and I'm not sure exactly how much it has been shaved my two questions are what the stock deck height of the d16y8 is and how much is safe to shave off the head????
I'm thinking of getting it shaved more if thats possible I just don't know how much to shave it and how much is too much???
any help would be greatly appreciated thanks!!
Old 01-13-2010, 08:51 AM
SLOWAUTOEX's Avatar
Default Re: shaved head question..
just found this for the deck height is that right for a y8?...8.347
Old 01-13-2010, 08:54 AM
SLOWAUTOEX's Avatar
ahh correction its not the deck height...
its how much can the head be milled...?
Old 01-13-2010, 09:59 AM
SLOWAUTOEX's Avatar
anybody??
Old 01-14-2010, 01:34 PM
SLOWAUTOEX's Avatar
Old 01-14-2010, 01:43 PM
vtechjunkie's Avatar
There are tabs on the under-side of the head that indicated how much is left on the head.
Usually int he corners of the head. Or wether or not you can go any further that is. As far as how much has already come off, I don't know.
Old 01-14-2010, 02:27 PM
sidock's Avatar
Why dont you find out what your actually looking for out of the head and tell the machine shop to do it...
Old 01-14-2010, 02:37 PM
SLOWAUTOEX's Avatar
"Usually int he corners of the head. Or wether or not you can go any further that is."
Can you explain that a little better, please?
Old 01-15-2010, 07:04 AM
SLOWAUTOEX's Avatar
"int he"=in the lol nevermind.
Old 01-15-2010, 07:15 AM
BigAnteg's Avatar
u can shave around 10 thousand off the head and will give u some pretty high compression but i wouldnt take it father than that i took off 10 thousand of my head cause i wasnt paying attention but it made alot of differnce
Old 01-15-2010, 07:20 AM
SLOWAUTOEX's Avatar
0.100 gets me 12.35:1
Old 01-18-2010, 05:13 AM
BigAnteg's Avatar
how much u trying to shave off cause if u start shaving to much ur going to start having problems of it over heating cause one time we had a camaro with a 502 that we shaved alot off the head and had problems over heating
Old 01-18-2010, 08:22 AM
newtron63h's Avatar
.100"? or .010"? .100" is one hundred thousandths. .010" is ten thousandths
Old 01-18-2010, 09:30 AM
I wouldn't go past .075. You don't want to have to run race gas all the time do you? After about 12.5:1 you have to start thinking about detonation.
Old 01-18-2010, 10:04 AM
willimo's Avatar
I milled a head .030 for just a little bump in compression. I wouldn't go further than that, really, and though you can technically go more, I'd agree with ^ and .075 is about as much as you want to go.
There are little circles cast into the underside of the head, near the corners. You'll see the shiny, milled surface that mates to the head gasket, there will be a C shape in that, and in the middle there will be a little circle that is cast in. It's hard to describe. That's your limit; beyond that you will be in danger of warping the head. I'll try to get a picture.
In any case, you need an adjustable cam gear. You'll be moving the cams closer to the crank, and that will affect your timing. You'll need to adjust it back a little bit or your car will run like a dog.
Old 01-19-2010, 02:34 PM
willimo's Avatar
You can see the limit casting on the lower left corner of the head in this picture. It's just below the dowel pin. You cannot mill it any more than that.
GannyX
Honda CR-V & Element
06-29-2015 12:35 PM
Quick Reply: shaved head question..
