Service check connector CEL behavior
Old 01-21-2017, 07:46 PM
ZaneKaminski's Avatar
Default Service check connector CEL behavior
Hello all. Simple question. When I plug in the service check connector, if I have no codes set, what does the CEL do? I was under the impression that if no codes are set then the light stays illuminated and doesn't blink at all. When I short the wires in my '98 HX, the CEL fails to turn on or flash. The CEL passes the self test when the car turns on of course. Is this normal? Or are my service check connector wires screwed up?
The reason I ask is because I'm adjusting the spark timing.
Old 01-21-2017, 09:52 PM
jonsey1886's Avatar
Default Re: Service check connector CEL behavior
Pictures of how you inserted the jumper wire please.
Old 01-22-2017, 08:48 AM
Hysterically Calm
TomCat39's Avatar
The behavior you described of how it's supposed to work is correct.
2nd this. It sounds like you may be miss jumping the service connector.
Old 01-23-2017, 02:36 PM
TheJGB3's Avatar
No stored codes = no blinking CEL when jumping the service connector
Old 01-23-2017, 02:40 PM
Hysterically Calm
TomCat39's Avatar
He noted awareness of that. The problem is the CEL doesn't come on or stay on solid with the service connector jumped.
That is a problem of one sort or another.
Old 01-31-2017, 06:55 PM
jonsey1886's Avatar
No response when offering help could you please reply or could a mod close this thread?
Old 02-01-2017, 05:59 AM
Hysterically Calm
TomCat39's Avatar
Why did you bump the thread?
Just unsubscribe from it and let it sink.
No reason to be vindictive and close the thread.
turbo sol
04-02-2009 05:31 PM
streetracerjoey210
08-05-2006 06:28 PM
stealth89hatch
08-15-2005 04:48 PM
beeroh
09-24-2004 08:16 AM
gsrvx
05-19-2002 05:25 PM
Quick Reply: Service check connector CEL behavior
