sealant for head gasket
Old 01-26-2011, 12:07 PM
redright9's Avatar
Default sealant for head gasket
So this comming weekend I am hoping to get the cylinder head back onto my civic. What are your thoughts about the spray sealants that are out there.. I have had some people say I should use some of the copper spray stuff.
Old 01-26-2011, 02:51 PM
skuded's Avatar
Default Re: sealant for head gasket
if the head isnt being resurfaced, or if it is resurfaced and its not to smooth of a finish, or if you just want to many people use copper spray on headgaskets, it shouldnt hurt anything to use it so go for it, are you having trouble with blown headgasket, cause if you are you will want to have the head resurfaced, most machine shops should be able to resurface it for you for about 30$, if you dont have it done you take the chance of the head being slightly warped and you could still have a leak
Old 01-26-2011, 03:17 PM
Cynical 1's Avatar
don't do it, unless you want to do another headgasket after it starts to leak...
Old 01-26-2011, 03:48 PM
hellah fresh's Avatar
dont do it. just get it resurface for 60 and use the gasket. stop cutting corners unless you want to take your heads apart again.
Old 01-26-2011, 04:01 PM
apexi_rsx's Avatar
a head gasket dont cost much just buy one. or your going to be doing this all over again not too far down the road
Old 01-26-2011, 06:15 PM
92lxsleeper's Avatar
well when i replaced my headgasket on my d15 a year ago i was a cheap f*** with no money and had a spare y8 headgasket laying around. the block was warped, the head was warped but i replaced the gasket and put it back together anyway. new water pump, thermostat and radiator and its running fine ever since.
new_climber
Honda Civic (2001 - 2005)
08-28-2023 12:11 PM
da_33
01-11-2007 11:12 AM
onlinehost
11-14-2005 08:14 PM
mulin
11-03-2004 09:25 PM
boostedel
04-06-2003 09:11 AM
Quick Reply: sealant for head gasket
