Benen front sturt bar install
Old 05-26-2009, 04:35 PM
ecko_3420's Avatar
Default Benen front sturt bar install
I just got a benen tripod front strut bar and would like to know what size hole to drill and nuts and bolts to use? Ive searched and none of the thread specified the size to use.. Thanks...I have a 97 civic hatchback...
Old 05-26-2009, 06:05 PM
ecko_3420's Avatar
Default Re: Benen front sturt bar install
bump
Old 05-26-2009, 06:51 PM
mynameizstitch's Avatar
should already have holes there. cuz on the eg6 there are holes there already and you will need a size 10 bolt. just take one of the bolt from your hood and go to a hardware store and buy the same bolt.
Old 05-26-2009, 06:52 PM
Meoshe's Avatar
Take it to the hardware store with you and browse their grade 8 bins for whatever fits. Then just use a drill bit that is right around the same size.
to stitch: 96-00 civics don't have the holes like earlier models.
Old 05-26-2009, 08:41 PM
ecko_3420's Avatar
grade 8? i read about that earlier...is there really a dif? how long should the bolts be?
Old 05-27-2009, 08:48 AM
Meoshe's Avatar
There is a difference in strength, I would say 1 inch is fine.
Old 05-27-2009, 09:57 AM
STOCK_SOHC_DX's Avatar
What? Carbing bar bolted to my fire wall of my EK, I just had to take out the black plastic plugs.
Old 05-27-2009, 01:05 PM
Meoshe's Avatar
Yeah that's because it mounts to the tophat studs. Note: I think he is talking about the mounts at the shock tower. The benen mounts to the top of the shock towers like the ITR/CTR/SI/GSR ones.
Old 05-27-2009, 04:03 PM
Oh that one, I remember I used the biggest ones that could fit the Mugen bar grade 8. On my friends car that we did wire tuck we got a body shop to actually order the whole SI shoulder and remove and replace that was gangster.
Old 05-27-2009, 11:42 PM
TheJGB3's Avatar
Yes 'grade 8' hardware is for automotive applications (harder/stronger steel).
Old 05-28-2009, 12:13 AM
taggart_lumpy's Avatar
watch how long the bolts are though
depending on how low you are they may hit you front upper control arm
Old 05-28-2009, 12:43 AM
hOnda_hiEn's Avatar
stick the bolts up from under.. LoL..
Old 05-28-2009, 06:04 AM
sanegb16's Avatar
thats what i do haha
Old 05-28-2009, 06:37 AM
I'm not Rick!
rick_rabies's Avatar
...weld it
Jaylom
08-16-2011 07:22 AM
mynameizstitch
03-11-2009 06:40 AM
nighthawkgsr
09-20-2007 06:52 AM
92civeg
06-20-2003 03:56 AM
Quick Reply: Benen front sturt bar install
