removing window crank/door panel
search but i could find anything...
how do i take the door panel off of a eg coupe(manual windows)? cant seem to figure out how to get the window crank off...
Re: removing window crank/door panel (pompom)
The window crank should have a little metal clip. You need to get a pick and remove it for the handle to come off. Just pull on the handke a little too see the metal clip.
the above is true. Also, this sounds dumb, but people forget it. Look for the screw inside the little plastic pocket/interior handle thing. After that stuff, the door panel pulls off with a little bit of tender love and prying.
memoryFAB.com representative
Re: removing window crank/door panel (Solice)
your gonna have to use 2 hands, one hand for a long flat head screw driver and the other with a pair of needle nose pliars.. or at least i did
What I found really handy was using a coat hanger, metal preferably so it doesnt bend. Then make a little hook on the end, and then use that to pop the clip. Also there is actually a tool designed to do this.
flatblk
07-12-2004 10:30 AM
Mentat Ghola
01-11-2003 04:47 PM
IdotheSHOCKER
08-15-2002 03:43 PM
