Rear Wiper Shave for EK. Instructions with Pics
Old 04-30-2008, 08:35 AM
93beccalx's Avatar
Default Rear Wiper Shave for EK. Instructions with Pics
Here’s a write up on one way to shave the rear wiper on an EK:
You will need:
Welder and someone who knows how to weld
14mm, 12mm, 10mm wrench/socket
Air grinder, sander, scuffer, 60-100grit sandpaper, 120-200grit, 400grit, Bondo (maybe), primer
1. First, you must remove the wiper assembly
a. Remove the plastic cover that’s hiding the wiper bolt then remove the bolt
b. Pry/pull off the wiper and remove the rubber grommet too
c. Now remove the plastic panel hiding the wiper motor from the inside of the hatch
d. Remove the three bolts and disconnect the electrical connection to remove the motor
2. Now that the motor is gone, I found it easier to just remove the entire hatch
a. Start by removing the plastic covers off of the shocks then unbolt them
b. Remove the right speaker grill by removing the three screws
c. Next remove the two gold screws and one silver bolt
d. You should now be able to pull back on the panel just enough to see the wires
e. Unclip the wires and pull them up through the top of the body
f. Finally, remove all four bolts holding the hatch on (it takes two people)
3. With the hatch removed you can see how much easier it is to work
a. Before you start to weld you need to remove the paint from the hole where the wiper was
b. Next, you must prepare another paint free surface for the ground connection
c. Make sure that the sheet metal is touching the hatch and make four tack welds
d. You may choose to turn the hatch over and repeat the welds on the other side
e. Be careful not to melt the rubber seal
f. After welding grind down the excess, sand it flush, and use Bondo fill in any spots
g. Resand and make sure you primer the area once you are done to avoid rust
h. Realign the hatch before you tighten the four bolts down and reinstall everything
I also choose to weld the hole where the water hose used to be below the top of the hatch. The process is the same.
Old 04-30-2008, 10:28 AM
bmoua's Avatar
props on the DIY but i'd honestly keep the rear wiper.
Old 04-30-2008, 01:03 PM
93beccalx's Avatar
Default Re: (bmoua)
some like it, some hate it. i hated mine, plus it is one more piece in my "jdm" conversion... hahaha. i hate those stupid letters now! J-D-M that's all you hear now.
but thanks for the props
Old 04-30-2008, 09:18 PM
EKstacy's Avatar
Default Re: (93beccalx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93beccalx &raquo;</TD></TR><TR><TD CLASS="quote">
props for doing a diy but i hope youre not finished with that
Old 04-30-2008, 10:22 PM
sayone's Avatar
Default Re: (EKstacy)
not really a good diy you need to show step by step process and all the materials you used
Old 04-30-2008, 10:52 PM
The Lobster's Avatar
good job...but ill stick with my rubber plug
Old 05-01-2008, 03:42 AM
SuperSonikBluEK's Avatar
Default Re: (The Lobster)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The Lobster &raquo;</TD></TR><TR><TD CLASS="quote">good job...but ill stick with my rubber plug</TD></TR></TABLE> yup
Old 05-01-2008, 07:03 AM
The Collin's Avatar
Just get a CX
Old 05-01-2008, 08:28 AM
-JAWSHUA-'s Avatar
i did the same to my old hatch. now i got a cx.
Old 05-01-2008, 02:06 PM
93beccalx's Avatar
Default Re: (-JAWSHUA-)
the cx doesn't have a rear wiper? what other differences are there between the dx?
Old 05-01-2008, 02:07 PM
93beccalx's Avatar
haha heck no that would be inviting rust. i didn't get around to primering it yet that day.
Old 05-01-2008, 02:08 PM
93beccalx's Avatar
Default Re: (sayone)
what more should i post?
Old 05-01-2008, 02:14 PM
DDEVIANT1's Avatar
ALSO make sure to tape up or properly cover the rear glass, or you will get welding pits in it . Looks good though.
Old 05-01-2008, 06:03 PM
93beccalx's Avatar
Default Re: (DDEVIANT1)
the hardest part is getting a flat contour with the Bondo.
Old 05-01-2008, 10:29 PM
sayone's Avatar
you should post the sheet metal, what you cut it with, what you used to grind down the weld iono other stuff to complete this DIY.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93beccalx &raquo;</TD></TR><TR><TD CLASS="quote">the cx doesn't have a rear wiper? what other differences are there between the dx?</TD></TR></TABLE>
yes the cx didnt have the rear wiper and the other diffrence between the cx and dx is the wing. the cx is all plastic while the dx is metal.
Old 05-02-2008, 05:25 AM
pdiggitydogg's Avatar
Very unwise to do this without disconnecting the battery... Perhaps you should edit your post to indicate it needs to be done, if welding on the car.
A welder like that can fry an ecu...
Nice job though, as long as you can weld
Old 05-02-2008, 03:48 PM
93beccalx's Avatar
Default Re: (pdiggitydogg)
We removed the entire hatch from the car but I didn't know that could have happened if we didn't.
Old 05-02-2008, 03:59 PM
DDEVIANT1's Avatar
It's is unlikely but it can happen.....just a note on that front, most muffler shops and bodyshops don't disconnect the batteries when they are welding.... if you ever need that type of work done make sure to mention that to them.
wood 1
03-18-2008 01:17 PM
FakeJDMEF8
09-26-2004 07:39 PM
dinosa21
02-06-2003 08:55 PM
Quick Reply: Rear Wiper Shave for EK. Instructions with Pics
