Problem with my horn.
Old 04-08-2009, 11:19 AM
fatalerror's Avatar
Default Problem with my horn.
I have a 2000 Honda civic DX, and last night something went totally wrong. I pushed the horn and it got stuck on, it was on and blaring in the parking lot for over 5 minutes, untill I could pull the fuse out. The problem is that the fuse controls the horn and brakelights, so i dont have brakelights, meaning I cant drive car now. My question, is where is the actual horn located on the car and how do I disconnect it, so I can put the fuse back in. I dont mind having no horn, just want brake lights. Thanks in advance everyone.
Old 04-08-2009, 11:24 AM
sirt_eg's Avatar
Default Re: Problem with my horn.
its inside your steering wheel. your going to have to take the srs airbag out and look at the horn button inside. its probably broken or mess up. first you have to remove the two covers and take the two screw, 1 from each side off the steering wheel. (there the star kind) than remove the air bag, dont forget to remove your negative battery first cause you dont want that thing blowing on you. than once you got the air bag out look at the horn button inside.
Old 04-08-2009, 11:26 AM
fatalerror's Avatar
Well, without doing all that, cant i just go to the horn under the hood and just unplug it? Then pop fuse in and brake lights work again?
Old 04-08-2009, 11:27 AM
sirt_eg's Avatar
you can unplug the horn in the front. I forgot where though, think its in the passenger side behind the bumper.
Old 04-08-2009, 11:34 AM
waaBAAH's Avatar
will have two wires connected to it. it is round in shape like a disc. black metal disc. will be up front and probaly inside the wheel area between wheel lining and front bumper corner
did you try pushing the horn buttons with a little more pressure then normal to possibly readjust the button? then try rotating the horn button forcefully with your thumb like if you thought it was a d-pad on a nintendo joystick and if you were trying to do a hyrukin with ryu in street fighter motion as well. lol
Old 04-08-2009, 11:50 AM
fatalerror's Avatar
Yeah, I played with the button like crazy, I tryed putting a penny's edge in there and pulling it up and did everything imaginable to it lol, its not stuck, has to be something else...
Old 04-08-2009, 11:53 AM
GetawayInMoscow's Avatar
The horn beeps when one of those buttons gets grounded. Cut the wires the the one that is causing it and you should be good to go
Old 04-08-2009, 11:56 AM
Former User's Avatar
These diagrams also may help:
Old 04-08-2009, 12:02 PM
fatalerror's Avatar
Thank you so much everyone, hopefully that diagram will do the job, Im going to walk out there right now and start working on it. Ill check back in here with the progress
Old 04-08-2009, 01:34 PM
fatalerror's Avatar
So this is what I did.... I unscrewed my grill to get to the horn, so that I didnt have to take off front bumper. I then pulled the cord out of the horn to turn it off. Then I put the fuse back in, and tested, everything works good now, just no horn.
Old 04-08-2009, 01:43 PM
When you have time, repair the switch in the steering wheel. The horn isn't just annoying, it's also a safety device.
Girls hair
Honda Civic (2001 - 2005)
01-11-2013 06:38 PM
TurboEM1
11-27-2005 08:48 AM
00CivicGirl
09-20-2005 06:26 AM
Beezle
10-15-2004 12:10 PM
LB CRX
11-24-2002 11:31 PM
Quick Reply: Problem with my horn.
