Power to Manual rack conversion (GSR Rack)
Old 09-07-2006, 04:45 PM
Eyal 951's Avatar
Default Power to Manual rack conversion (GSR Rack)
I looped my new GSR rack with a breather resevoir. I used a new clutch master resevoir to do the job.
I used:
-1 3/8 Barb T ($2-3)
-1 3/8 to 1/4 barb adapter ($2-3)
-2 feet 3/8 hose (That should leave you with extra) ($2-3)
-2 feet 1/4 hose (That should leave you with extra) ($2-3)
-8 little hose clamps (free for me)
-fitting on rack, I think its 14x1.25 to 3/8 barb, but please verify, I forgot! ($12)
-Factory clutch master resevoir, cap, and bracket. I recomend the floater as well ($30)
Not a write up, but at least some pics. Let me know if you have any questions
Old 01-30-2007, 06:44 AM
THC07's Avatar
Default Re: Power to Manual rack conversion (Eyal 951)
did you make the breather? looped + breather for efective manual rack
Old 02-21-2007, 08:24 PM
Eyal 951's Avatar
Default Re: Power to Manual rack conversion (THC07)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by THC07 &raquo;</TD></TR><TR><TD CLASS="quote">did you make the breather? looped + breather for efective manual rack</TD></TR></TABLE>
the breather is an OEM honda clutch resevoir, and yes looped + breather makes for quite an effective manual rack.
Old 02-22-2007, 08:42 AM
MonkeyPuzzle's Avatar
is the reverse also possible, I have 96 dx without power steering that I would like to make power?
Old 02-24-2007, 02:52 PM
Eyal 951's Avatar
Default Re: Power to Manual rack conversion (MonkeyPuzzle)
you need to source a power rack, pump, and hoses. You might need a crank pulley, may not. then install it all.
Old 02-25-2007, 12:45 AM
EH6TunerDaniel's Avatar
You are kind of um, missing your suspension there....lol. Anything else you know of to use as a breather? How about the stock power steering reservior?
Old 08-26-2008, 06:16 PM
STN_Pat's Avatar
Default Re: (EH6TunerDaniel)
I have the looped set-up but w/o a breather.
Will it makes any significant difference to have it T-ed and open to the atmosphere ?
Thanks for your inputs.
I'll soon just go and try it out for myself...but maybe someone has an answer for me.
thanks !
chevymeister
11-11-2013 07:52 PM
RookieCivic
12-12-2011 10:18 AM
SQ is the SQUAD
Suspension & Brakes
12-06-2010 10:16 AM
vtec4lyfe
01-08-2007 07:46 PM
rjr162
08-18-2003 09:41 AM
Quick Reply: Power to Manual rack conversion (GSR Rack)
