Manual Steering Rack Conversion
Old Nov 10, 2013 | 12:32 PM
chevymeister's Avatar
Default Manual Steering Rack Conversion
Don't get me wrong, I've read lots of guides and have everything ready. (3/8 Nylon tee (all I could find) and a 3/8 hose barb with 1/4 thread on it)... I just couldn't figure out the part about the breather. If I were to say get a res for a power steering pump, it basically needs an off shoot like a coolant res to vent air out (overflow hose?) or does it just need a res that is lidless.
Thanks in advance
Old Nov 10, 2013 | 07:06 PM
B_Swapped93's Avatar
Default Re: Manual Steering Rack Conversion
you do know a manual rack is non power assisted right lol as in no pump or res. what car is this on?
Old Nov 10, 2013 | 07:17 PM
Oops meant power in the title. I know the difference... It's just a Freudian slip.
It's in my 98' dc4. I'm just under the impression I can't drill a hole through a res and call it a breather so I don't know if I need to find a certain 'breather reservoir' that would function as a moisture barrier.
Old Nov 10, 2013 | 07:24 PM
I'm confused as to why you need a breather, never heard of it being needed when swapping from a manual to power. but my guess would be to use a T fitting with a breather somewhere on the rubber line(s).
Old Nov 10, 2013 | 07:44 PM
Well most guides I see say that it becomes pressurized if you just loop the input/output which makes sense so it resists a lot more than if you added a breather on the tee (which I purchased) i'm just confused as to what to use for a breather in the loop. It's power steering btw, I'm just removing the pump and whatnot.
Old Nov 10, 2013 | 07:54 PM
ohhh lol well you know a "manual rack" is physically a different item, I just removed the P/S on my gsr, what you do is before you loop it turn the wheels L-R a few times to get excess fluid out. you can do the breather but just easier to get most of the fluid out then loop it.
Old Nov 11, 2013 | 07:52 PM
For anyone wondering the OEM reservoir acts as a 'breather', the lid has holes in different spots that allow pressure to vent. Just took some spare 3/8's hose and hooked the oem res to a tee and now works.
bizzle2288
Aug 27, 2012 05:29 PM
SQ is the SQUAD
Suspension & Brakes
Dec 6, 2010 10:16 AM
vtec4lyfe
Jan 8, 2007 07:46 PM
rjr162
Aug 18, 2003 09:41 AM
