Plan to swap 96 b18b1 into my 99 Si - Need help with wire harness and ECU questions
Old 01-06-2011, 01:53 PM
gsr95jacob's Avatar
Default Plan to swap 96 b18b1 into my 99 Si - Need help with wire harness and ECU questions
I have a 1999 civic si (canadian, so d16y8). I am planning on putting a 1996 b18b1 in it this winter. I am wondering where my car is OBD2b will it match up to the OBD2a in the b18, or do I need a conversion harness?
Also do I use the stock 99 si harness and ecu and just change the distributer plug? And is there any other wiring that will need to be changed?
I know this has probally been asked a million times, but i have had a hard time finding a direct answer. I have never done a swap before. Sorry about the repost everyone!
Thanks for your time,
Jacob
Old 01-07-2011, 12:53 AM
Stancetard Hate Monger
eghatch9295's Avatar
Default Re: 99 si swap, quick question!!
ive gotta ask: why a ls swap? power gain is minimal, tq is not very significant. if youre going to put yourself thru it, AT LEAST go b16.
Old 01-07-2011, 12:56 PM
-__-'s Avatar
he has his reasons...maybe it was cheap? maybe he wants to turbo? maybe he wants to do an LS/VTEC? maybe thats all he could find? maybe cuz b16 have no torque and he wanted torque?
i assume your car has a manual transmission? anyway, you can use your stock obd2b harness and use an obd2b LS computer. u may have to splice on a new clip for a couple things but its not hard. dont forget axles, mounts, transmission and shift linkage. good luck
Old 01-07-2011, 01:25 PM
jdm_phunk's Avatar
Default Re: Plan to swap 96 b18b1 into my 99 Si - Need help with wire harness and ECU questio
check out= http://www.rywire.com/catalog/ or call them (240-479-9473)
Old 01-07-2011, 01:32 PM
itsmejto's Avatar
$500.00 for a wiring harness ...... are you crazy ?
Old 01-07-2011, 02:11 PM
gsr95jacob's Avatar
Alright. So ill need to find a obd2b ecu for the ls. I cant use the obd2a ecu.
And yeh its 5 speed.
Old 01-07-2011, 02:15 PM
gsr95jacob's Avatar
because i was given a complete swap for free. whats wrong with a ls swap, mroe power then a 1.6bsohc?
Old 01-07-2011, 02:38 PM
The Grumpiest
grumblemarc's Avatar
Dammit. Someone give ME a swap for free. I live in Oak Ridge TN. I'd swap that in and boost it.
Old 01-07-2011, 02:46 PM
Seagull Management
94EG8's Avatar
Use a conversion harness, all the OBD2B Integra ECUs have an immobilizer and can't be used unless you have it removed.
Old 01-08-2011, 10:49 AM
gsr95jacob's Avatar
alright thanks. what do i get for a conversion harness, 0bd2b to 2a or the other way around.
Old 01-08-2011, 11:46 AM
Seagull Management
94EG8's Avatar
OBD2B to OBD2A
Old 01-08-2011, 01:23 PM
94dxcoupe's Avatar
B to A
www.hamotorsports.com/obd2btoobd2a.html
"OBD2B to OBD2A ECU jumper harness to install a 96-98 civic or 96-99 integra ECU into any 99-00 civic or 00-01 integra chassis"
Old 04-25-2011, 09:05 PM
ej8civic281's Avatar
i also need help on my first ls swap into my 99 civic d16y8,i got it for cheap thats why im swapping this,
what will i need to swap it,they told me i needed a obd1 ecu and ls harness
t bracket and si sidepost,b series mounts? is it true?
Old 04-25-2011, 09:20 PM
Crazy Honda Guy
Deetz's Avatar
This must be a Canadian Si? Same as the US EX i am assuming if you have a sohc
choua01
11-20-2008 06:55 PM
clean-jdm-ek
05-31-2006 08:43 PM
xvallmoto
12-19-2003 01:46 AM
aeolus
12-08-2002 07:38 PM
EEK
07-09-2002 01:09 PM
Quick Reply: Plan to swap 96 b18b1 into my 99 Si - Need help with wire harness and ECU questions
