P420 Fix?
Old 04-04-2010, 05:08 AM
Lord of the idiots
[ej]Jonathan's Avatar
Default P420 Fix?
i have a 98 ej and its throwing a p420 code. i replaced the o2 sensor but i have a high-flow cat. is there any way to bypass this code? i know im not the only person on here with an OBDII car with a high flow cat, so i refuse to put the stock cat back on.
Old 04-04-2010, 05:10 AM
Resident Gearhead
BryanM.'s Avatar
Default Re: P420 Fix?
An 02 simulator can bypass the P0420 trouble code. Give me a minute and I'll dig up the link.
Old 04-04-2010, 05:16 AM
Resident Gearhead
BryanM.'s Avatar
I went to this site only two weeks ago and the had simulators specifically for Honda engines. Now they don't, and only have universal ones, which I'm sure will work.
http://www.o2simulator.com/index.php...products_id=10
Old 04-04-2010, 06:41 PM
Lord of the idiots
so how does that work?
Old 04-05-2010, 04:46 AM
anoble1's Avatar
I have a 1998 Honda Accord with 155,000 miles. The check engine light recently came on with the P0420 code. I replaced the rear sensor with a bosch and I replaced the cat (not an oem). I am still getting this stupid light coming back on every 45 minutes after I cut it off. Will this work for mine also, or is this another problem?
Old 04-05-2010, 04:51 AM
anoble1's Avatar
Also, I was getting 30mpg before the light came on, now i am getting 22mpg.
Old 04-05-2010, 05:29 AM
Jimster480's Avatar
Or you can build one yourself!
http://www.mkiv.com/techarticles/oxy...sor_simulator/
Old 04-05-2010, 05:35 AM
Lord of the idiots
so does that simulator just plug into the o2 sensor plug, or into the ECU somewhere?
Old 04-05-2010, 05:39 AM
Jimster480's Avatar
I am not 100% sure, you will have to look. But I think it splices into the O2 sensor wiring from the looks of it. Obviously htough you will have to splice it based on your ECU Diagram and not based on the one there for a Supra :X
Old 04-05-2010, 06:57 AM
Lord of the idiots
oh, no i meant this one
Old 04-05-2010, 07:47 AM
crxmadness's Avatar
Here you go:
http://cgi.ebay.com/ebaymotors/TEST-...item5ad333a9bc
no wiring
just screws on
stainless steel so it wont rust
Old 04-05-2010, 08:17 AM
supersize's Avatar
i dont understand how that would work lol.
Old 04-05-2010, 01:05 PM
Jimster480's Avatar
I'm not sure how that would work, unless its filled with cat material.
Old 04-07-2010, 10:07 AM
crxmadness's Avatar
It works, I used it on every civic and accord I have owned. Use the search button if you dont believe me.
Old 04-07-2010, 10:18 AM
D16SiHatch's Avatar
i've heard of people using those things for many years now. best i can figure is with the sensor further from the exhaust stream it reads less hydrocarbons and therefore prevents the catalyst efficiency code from being thrown.
vaguy
12-31-2017 11:59 AM
poop32145432
08-05-2004 01:48 PM
onyx00
04-20-2002 12:32 PM
onyx00
04-16-2002 01:00 PM
AllMotorBLKITR731
10-17-2001 12:39 PM
Quick Reply: P420 Fix?
