99 Civic LX - overheating problem
Old 09-05-2012, 05:46 AM
calteg's Avatar
Default 99 Civic LX - overheating problem
I have a 99 civic LX that recently began overheating. It drives fine for roughly 20 minutes, then the temp gauge starts climbing and eventually maxes out. Happens both idling and at speed, though it cools down very slightly at speed.
The strange part is that the A/C seems to be tied to the overheating. A/C works fine for the first 20 minutes or so, as the car overheats, the A/C begins cutting on and off. It'll work fine for 3 or 4 minutes, then blow hot air.
I'm going to swap out the thermostat and bleed the system, any other suggestions?
Old 09-05-2012, 06:15 AM
axis11's Avatar
Default Re: Wierd overheating problem
First verify that the radiator fan is turning on.
Old 09-05-2012, 06:39 AM
Ryan Lwin's Avatar
Caps. Check for them or replace them. They are cheap.
Old 09-05-2012, 07:30 AM
Cody Pereira's Avatar
thermostat sticking? Im coming from the American muscle world and I know that when the thermostat sticks and doesn't open up when the motor gets to temperature it will cause the motor to overheat. Check it out, its a cheap fix too!
Old 09-26-2012, 10:13 AM
calteg's Avatar
Thermostat has been swapped, system was burped properly, verified that both fans come on when they're supposed to. Also did a head gasket test, no exhaust gas is leaking into the cooling system...kinda stumped.
Temp seems to be okay as long as I'm at speed. A/C on or idle too long and it starts to overheat. The odd thing was, after I burped the system, it ran fine for 2 days, then started acting up again. Ideas?
Old 09-26-2012, 01:26 PM
Former User's Avatar
NEVER let your engine overheat to this level. If it hasn't happened already, you will destroy your engine.
Does the radiator fan run when the engine gets hot?
Is the lower radiator hose much cooler than the upper one when the engine gets hot?
jpuleo
24
08-05-2015 01:27 PM
simplegreenmachine
13
12-12-2009 04:07 PM
ilinan87
08-26-2009 04:19 PM
TEGSTEG
11
10-16-2007 07:56 AM
Quick Reply: 99 Civic LX - overheating problem
