Oil leak on oil lan where transmission meets...main oil seal?
Old 12-30-2010, 11:08 AM
05foresterxt's Avatar
Default Oil leak on oil lan where transmission meets...main oil seal?
My 99 Si had a couple of oil leaks. Replaced the vtec seal, vapor canister seal, and oil pan gasket. But I'm still seeing a good amount of oil leak right in the area on oil pan where the tranny meets the engine. Could this be the rear main seal? Is there any way to fully check where the leak is coming from?
Old 12-30-2010, 11:17 AM
macson's Avatar
Default Re: Oil leak on oil lan where transmission meets...main oil seal?
I would look into rear main. However, I had a transmission with a blown ISB so bad that leaked trans fluid in that same area; took my clutch with it. I assume you're okay in that regard, however. ;P
Clean it all up and see if you can pinpoint where it's coming from, easier when the engine's not covered in grime.
Old 12-30-2010, 11:20 AM
95ProjectEJ1's Avatar
Originally Posted by macson
...Clean it all up and see if you can pinpoint where it's coming from, easier when the engine's not covered in grime.
x2...definitely clean it up so you can get a clear idea as to where the leak is coming from. I have had leaks in the past that appeared to come from below, but actually started from above. Purple power and a pressure washer will do the trick. Just make sure the motor is cold.
Old 12-30-2010, 11:24 AM
I've cleaned it up twice, but can't figure it out. The transmission is not having any problems and I don't see any leaks from it.
Old 12-30-2010, 03:34 PM
4dregDC's Avatar
Had same issue rebuilt my motor and put everything spankin new seals n gaskets so wen the time came to fire it up everything was still fine no leaks it wasent until I drove it that my tranny would leak between block n tranny case so I thought it would be rear main seal n it wasent turns out it was the trannys intermediate shaft seal
Old 12-30-2010, 03:41 PM
Hmmmm...where is this seal on the tranny?
Old 12-30-2010, 03:46 PM
Linked's Avatar
the input shaft bearing is in between the engine and the transmission where the clutch or torque converter would be at
if that were the case you'd have tranny fluid on the ground
although the rear main is the probable cause, check uptop for a leak at the distributor and vtec solenoid gasket cause it can flow down to the same spot on the ground
Old 12-30-2010, 03:48 PM
4dregDC's Avatar
I didnt know either so I called my mechanic he explained to me dat in order to get to dat seal u have to open up the tranny case ill find out til monday since he is on vacation for da holidays, keep in mind im not tellin u dis is da problem in ur car just letting u knw wat my problem was
Old 12-30-2010, 03:50 PM
I already replaced the vtec gasket and have killed all the other leaks. this is the only one left, but I'll double check everything.
If the leak is within the clutch/tranny area, I'll be putting in new main seal, clutch, and imput shaft seal just to be safe.
You have to crack open the tranny case to get to it? From there does it leak then?
Old 12-30-2010, 03:58 PM
4dregDC's Avatar
When the seal wears off oil finds its self through and eventually leaks u wont see the seal unless the case is apart
Seagull Management
94EG8's Avatar
5 speed transmissions have the ISB seal under the ISB on the inside of the case. You have to remove the input, countershaft and gears to get at it. You also have to remove the ISB which you'll probably ruin in the process, so make sure you get the bearing and the seal or you'll be waiting for parts. The automatics are on the outside of the case (OP has a 5 speed though)
Btw, you might also wanna check the distributor O-ring, sometimes that can look like a an oil pan gasket or rear main seal leak.
Old 12-30-2010, 03:59 PM
Linked's Avatar
to replace the input shaft seal? yes, if its more than you want to bite off, if its not leaking, leave it alone
noodlez1390
01-05-2009 04:29 PM
Beau Gotti
02-24-2008 12:11 PM
mwstrick
07-24-2007 09:19 PM
95LXDRIVER
12-01-2005 10:35 AM
92ehatch
11-10-2005 02:16 PM
Quick Reply: Oil leak on oil lan where transmission meets...main oil seal?
