Oil Leak 99 EX Front Pulley Area
Old 08-08-2015, 09:55 AM
drsab2000's Avatar
Default Oil Leak 99 EX Front Pulley Area
It's been a while since I've posted because the car was running great. The car has developed an oil leak in the front of the engine. The oil is dripping from the vent hole in the lower cover. It was time for a timing belt change (195K) so I dove in. After removing the upper and lower covers, there was not a lot of oil around the crank and cam seals but there was oil aroung the dipstick tube. There was no oil on the belt or sprokets. The face of the head and block has oil on it. So I changed the crank seal, cam seal, dipstick tube o-ring, valve cover gasket, water pump, idler and all the belts. Drove the car about 30 miles, put cardboard under it and an hour later, same oil leak. The oil pan gasket was changed about 3 years ago when I did the rear crank seal. What did I miss? Is it possible it's the head gasket? Car runs great. No oil in antifreeze, no antifreeze in the oil. Plugs look great. 1999 Civic EX needs help! Thanks in advance.
P.S. I hate that crank pulley bolt.
Old 08-08-2015, 10:09 AM
Former User's Avatar
Default Re: Oil Leak 99 EX Front Pulley Area
<p>The oil pump is another common site for an oil leak behind the lower cover. &nbsp;Did you inspect that area with the crank pulley off?</p><p>Removing the oil pump, replacing the O-ring, and forming a new gasket with HondBond fixed my leak.</p>
Old 08-08-2015, 10:46 AM
drsab2000's Avatar
Thanks Ron. I did remove the pulley and cover and inspected that area. There was signs of oil but I couldn't pin point the source. I found info on this site regarding the oil pump o-ring. I did not change that one. If I have to take this apart again, I want to get it right. How likely is this a head gasket oil leak behind the cover? Is there oil passing throught the block into the head in this area? I don't see any signs of oil around the head-to-block seam outside the cover. Thanks again.
Old 08-08-2015, 04:03 PM
Hysterically Calm
TomCat39's Avatar
This is my secret weapon for crank pulley bolts.
If 730 ft-lbs of torque can't break it free, then something is seriously wrong.
The other challenge was finding a 3/4" drive 17mm socket which I just got recently.
Torque Multiplier | Princess Auto
Stanley J07517M Proto 6 Point 3/4-Inch Drive Impact Socket, 17mm: Amazon.ca: Tools & Home Improvement Stanley J07517M Proto 6 Point 3/4-Inch Drive Impact Socket, 17mm: Amazon.ca: Tools & Home Improvement
Looks like this:
https://honda-tech.com/general-discu.../#post50461115
Old 08-08-2015, 04:09 PM
<p>
</p><p>It's possible, just not as common as the oil pan gasket, crank and cam seals, and oil pump for a leak from behind the lower cover.</p>
Old 08-08-2015, 05:01 PM
drsab2000's Avatar
To Tomcat: Thanks for the info on the 3/4 inch drive solution. I was able to loosen it with a 1/2 inch drive extension attached to a breaker bar and the 5 foot handle from my pump jack as my cheater. WOW when it breaks, look out.
To RonJ: Your advise has helped me in the past (rear crank seal) so I hope your "Honda Zen" is correct about the head gasket and it's just the oil pump o-ring.
Thanks for your help again!
Old 08-08-2015, 05:11 PM
<p>
To RonJ: Your advise has helped me in the past (rear crank seal) so I hope your &quot;Honda Zen&quot; is correct about the head gasket and it's just the oil pump o-ring. Thanks for your help again!
</p><p>The oil pump O-ring itself would not cause the oil leak. &nbsp;The leak generally is from the HondaBond gasket you create after you carefully scrape off the old gasket material. &nbsp;Buy a small tube of&nbsp;HondaBond from Honda, and consult your service manual. &nbsp;While the oil pump is off, replace the O-ring and the gasket for the oil strainer.</p>
Old 08-08-2015, 05:47 PM
Hysterically Calm
TomCat39's Avatar
Another little tip about the hondabond/flange sealant bit you might find helpful.
Besides scraping off the old material, cleaning the areas (block and pump surfaces) with non chlorinated brake cleaner will remove any oil residue and evaporate residue free.
This procedure leaves the mating surfaces clean and fully prepped for the hondabond/flange sealant to adhere to the metal.
Kyle700
01-18-2015 04:57 PM
coryfenton
14
06-10-2009 10:20 PM
oldskoolDA6
11-26-2007 02:17 PM
immalooser
05-17-2006 03:27 PM
ludelvr
12-19-2003 11:01 AM
Quick Reply: Oil Leak 99 EX Front Pulley Area
