OBD1 Oxygen sensor wiring CHECK.
Old 06-23-2005, 05:58 PM
MugenHonda's Avatar
Location: With my POS D15B2, Whereever whenever, United States
Default OBD1 Oxygen sensor wiring CHECK.
OK I am wiring my z6 and only have this to ponder
I had a 4 wire o2 sensor before the car.
here is what i got
the green wire goes to a ground
the white wire goes to d14
and the two other black wires go to a pin out on the ecu
is that correct?
MugenHonda is offline
Old 07-17-2005, 01:35 AM
ALLMOTORCRX20's Avatar
Default Re: OBD1 Oxygen sensor wiring CHECK. (MugenHonda)
WHITE--->D14
GREEN --->GREEN/WHITE--->D22 (this also goes to TPS, Intake Air Temp sensor and Coolant Temp Sensor)
BLACK--->YELLOW/BLACK--->JUNCTION CONN C125 (this is on the driver side, you will see a lot of yellow/black wires go to this connector. Its sealed on one side)
BLACK--->ORANGE/BLACK--->A6
ALLMOTORCRX20 is offline
Old 08-05-2014, 08:12 AM
gabrielsousa's Avatar
can i connect the o2 sensor ground on ( A23 or A26 or B2 ) ?
gabrielsousa is offline
Old 08-05-2014, 04:34 PM
Technical Hero
HondaPartsHero's Avatar
Just ground it at the factory ecu location
HondaPartsHero is offline
Old 08-05-2014, 05:47 PM
Former User's Avatar
You bumped a 9 year old thread (ancient). Don't do that. Instead, create your own new thread.
Former User is offline
sgallagher
08-05-2014 09:15 AM
orlandoEM2
03-23-2010 07:23 PM
R883
07-21-2008 11:52 AM
downest
05-15-2006 08:19 PM
Quick Reply: OBD1 Oxygen sensor wiring CHECK.
