Not able to reset/pull SRS codes
Can someone help me figure out why I can't reset my SRS light on my '94 Del Sol? It's been on for a few months now and I can get it to go away. It came on one day after I replace the cluster back light bulbs and turned on the ignition without the SRS plug plugged in and now I can't figure out how to reset it or pull the codes. I've tried jump the memory reset connector, but the light never goes out when it's jumped and it doesn't flash any codes when I jump the service connector.
Re: Not able to reset/pull SRS codes
I put a wire into each pin of the yellow connector by the fuse panel and then turned on the ignition and waited and nothing happened. I obtained both the reset procedure and the code pulling procedure from you.
Does it matter? I just need help figuring out why nothing is working. It's off whatever thread you have saying how to reset SRS light and many other things. You told me to try to pull codes, but when I tried that, it never blinked to give me any codes. I know there's nothing wrong with the system. I just need to reset the light and the yellow connector is not working to do that.
https://honda-tech.com/honda-civic-del-sol-1992-2000-1/how-pull-cel-d4-srs-abs-codes-code-lists-1901557/
Your tutorial thread.
https://honda-tech.com/honda-civic-del-sol-1992-2000-1/94-del-sol-si-changed-cluster-lights-now-srs-light-3268383/
My first thread asking for help in which you gave info on how/what to do and nothing worked, so now I'm back saying that nothing worked.
CC and horn fuses were voltage tested and neither have power. I checked all fuses and none are blown. You were adamant on pulling codes, so I tried to do that and I couldn't get the light to blink any codes out.
I'll go to a real Honda Tech and get some info and post up here in case anyone else has the same problem in the future.
Is that the Honda service manual for the 94 Del Sol?
http://www.ebay.com/itm/1994-HONDA-C...BWx6xv&vxp=mtr
The SRS system is usually the last section of the Electrical chapter.
Post the SRS circuit diagram from your manual. Does it look like this?
Is the diagram for the 94 Del Sol? If so, it explains why you were unable to pull codes by jumping the service connector or to reset the SRS control unit. The reason is because your car has an earlier version airbag system, and you were using SRS code pulling/reset methods specific to a later airbag system.
You need to pay to play.
You could download the 92-95 Civic manual and follow the SRS diagnostics there. However, the wiring information may be slightly different for the Del Sol.
RATEDR
07-13-2009 11:51 AM
