My passenger window rail??
Old 11-02-2012, 03:56 PM
sixtoek's Avatar
Default My passenger window rail??
I have lube and place grease on the track and also the rubber seal where the window track goes. It still goes up slow and im pretty much at a stuck point. I was thinking it might be just the motor ? What do you guys suggest i should do?
Old 11-02-2012, 05:13 PM
yessewey's Avatar
Default Re: My passenger window rail??
Put silicone spray on the tracks not grease and see if that fixes the problem, also be sure to make sure you aligned the tracks correctly because that could also be causing the issue. If all else fails then at that point I think it's safe to say that the motor might be the issue. If anyone else can think of anything I might have skipped over as it's been a few years since I had to deal with that issue.
Old 11-02-2012, 09:11 PM
sixtoek's Avatar
Thanks bro .. ill tey thay tomorrow but is there a special brand or any silcone spray ??
Old 11-02-2012, 09:29 PM
sixtoek's Avatar
Would this product me fine ?
loup05
11-22-2005 12:07 PM
rasinhell
05-20-2005 12:38 AM
DannyITR
09-16-2004 07:11 PM
aZnjCC
11
08-16-2004 07:51 PM
M0NEYnH0s
02-26-2002 12:18 PM
Quick Reply: My passenger window rail??
