map sensor and iac plug. please take a look.
Old 10-08-2007, 05:23 PM
* B A N N E D *
mustang5.slow's Avatar
Default map sensor and iac plug. please take a look.
d16y7 motor
d15b intake manifold
97 manual honda civic hatch.
p2e ECU
do these cars use a 3 wire iac sensor. because the intake i got has a 2 wire and there are 3 spliced wires that are just hanging there. and i connected a plug into this iac valve and the ECU is throwing 14
also it is throwing a 3 witch is the map senor.
this intake mani. does not have the sensor up top? and the car has the plug for it. instead the intake mani. has a nipple up top. what to i to about the map sensor.
Old 10-08-2007, 05:55 PM
97Ej6mike's Avatar
Yes, the P2E (d16y7) Reads for the oh-so-lovable 3-wire Idle Air Control valve setup. You must run a Throttlebody that supports it, or do the wire conversion. Is your idle normal, or is it loping?
Old 10-08-2007, 05:59 PM
* B A N N E D *
Default Re: (97Ej6mike)
well its not too out of wack (idle)
but what intake manifold do you suggest besides the y8 and y7
Old 10-08-2007, 06:03 PM
97Ej6mike's Avatar
If you are running the P2E ecu that reads for the 3-wire IACv, i suggest you either get a direct y7 replacment, or if you feel like 'upgrading', get an intake manifold off any 96-00 civic EX Automatic, all 96-00 automatic's (including the d16y8) use a 3-wire throttlebody mounted IACv.
All 96-00 Civics with the D16y7 have the 3-wire, that includes auto and manual's.
All 96-00 Civic EX automatics have the 3-wire IACv
All 96-00 Civic EX Manual's (and 99-00 SI) use the 2-wire IACv in the back of the manifold.
Old 10-08-2007, 06:50 PM
* B A N N E D *
thanks allot for you help 97Ej6mike if i need anything else I'll bump my thread.
once again 97Ej6mike i appreciate your help.
Randyb18
08-09-2015 03:07 PM
CRXguy_88
07-11-2010 09:10 PM
jaredvabeach
01-30-2007 01:44 AM
soulrider4ever
10-27-2005 04:12 AM
EGHatchy
16
07-13-2002 09:26 PM
Quick Reply: map sensor and iac plug. please take a look.
