Many CEL codes and fuse 15 keeps blowing/Suggestions for 98 civic hatch cx
Old 09-12-2011, 01:16 PM
mikeycivic's Avatar
Default Many CEL codes and fuse 15 keeps blowing/Suggestions for 98 civic hatch cx
4 codes and they are as follows
P1298 Electric Load Detector (ELD) Circuit High Voltage
P0135 Primary Heated Oxygen Sensor (Primary HO2S) (Sensor 1) Heater Circuit Malfunction
P0141 Secondary Heated Oxygen Sensor (Secondary HO2S) (Sensor 2) Heater Circuit Malfunction
Now when I checked the codes today I also had a P0500 Vehicle Speed Sensor (VSS) Circuit Malfunction, but after I reset the codes all of them have come back immediately except the VSS code.
What should I look at? Is this an O2 issue? Im not sure where to start since there are so many codes. This happened out of no where last week. Car seems to perform the same but all the dash lights, headlights etc. blink. Not blink as if on and off but more like bright dim bright dim and it eventually stops. Any suggestions would be appreciated.
Old 09-13-2011, 02:48 AM
mikeycivic's Avatar
Default Re: CEL Help/Suggestions 98 civic hatch cx
up
Old 09-13-2011, 05:22 AM
JDM-sol 89's Avatar
From what I've read, it sounds as if you may have to change out your whole fuse box.
Old 09-13-2011, 05:44 AM
Former User's Avatar
Check for a blown 7.5A dash fuse 15 and then click the Fuse 15 TSB link in my signature.
Old 09-14-2011, 02:43 AM
mikeycivic's Avatar
thanks ROn ill try it
Old 09-21-2011, 03:57 AM
mikeycivic's Avatar
so fuse 15 def keeps popping, I am going to try the "fix" in your link today.
jcuetizzi
01-23-2013 02:51 PM
Civic Racer X 7
13
06-01-2011 04:56 AM
jrami020
10-18-2009 02:24 PM
Devious951
10
08-29-2009 10:22 AM
suzuki1211
12-30-2008 11:33 AM
Quick Reply: Many CEL codes and fuse 15 keeps blowing/Suggestions for 98 civic hatch cx
