knocking noise when braking
Old 07-24-2006, 08:48 PM
Lissav's Avatar
Default knocking noise when braking
Car: 2000 Civic EX with ABS
Whenever i drive and press the brakes lightly just to slow down my speed there is knocking noise coming from my driver's side wheel well.
I just changed the driveshaft recently, it made the noise before and after if it matters. I thought it might be the ABS sensor, so i unbolted it and just zip tied it to the side to see if i still get a knocking. Once i drove it kept doing the knocking/clunking sound like something is loose. So i put the abs sensor, the noise continues. Today i took apart my driver's side brake, took the caliper and and pads off, everything is in check, nothing was loose, brake pads are brand new from Honda, everything is pretty new and the car is maintained mint.
What could this be, i've ruled out wheel bearing since that's not the type of noise it makes, plus why would it only make it when i touch on the brake pedal lightly?
When i press the brake more firm (usually when coming to a complete stop) there is no noise.
Old 07-24-2006, 09:05 PM
Solbros Owns Me
Evs-One's Avatar
Default Re: knocking noise when braking (Lissav)
sure it's not from the rears? Try pulling the ebrake handle gently and see if it does it. I've heard many a cars make noise like this from the drums
Old 07-24-2006, 09:13 PM
Lissav's Avatar
Default Re: knocking noise when braking (Evs-One)
E brake functions 100%, it's definitely the front driver's side. I can hear it loud and clear when driving by a wall slowly with my window down.
Old 07-25-2006, 01:16 AM
ICEMAN707's Avatar
That driver's front rotor might be warped. Get a new one.
Old 07-25-2006, 02:39 AM
JEM MotorSports's Avatar
check your axles... if you've recently replaced them with rebuilt axles. I'd ask where you bought them what types of policies do they honor. Most are cool about it and will swap them out on the spot if they were only used within a reasonable time.
Old 07-25-2006, 06:16 AM
Revtek 2's Avatar
It's most likely your axles... I had the same issue on my 95 Civic but mine was on the passenger side, replaced the axle and then everything was fine....
Old 07-25-2006, 06:40 AM
philosofy1's Avatar
Default Re: knocking noise when braking (Revtek 2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ICEMAN707 &raquo;</TD></TR><TR><TD CLASS="quote">That driver's front rotor might be warped. Get a new one.</TD></TR></TABLE>
i've never really heard of rotors making this noise, but they will vibrate like hell during braking when they are warped.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Revtek 2 &raquo;</TD></TR><TR><TD CLASS="quote">It's most likely your axles... I had the same issue on my 95 Civic but mine was on the passenger side, replaced the axle and then everything was fine....</TD></TR></TABLE>
exactly my thought, check your axles again.
Old 07-25-2006, 07:31 AM
Andres-eh2's Avatar
i have the same problem. but im leaning more towards the tie rod or LCA bushings. Ive changed brakes, rotors, and axles along the way and it doesnt go away. it could also be something with the steering rack
Old 07-25-2006, 07:40 AM
spoonracer84eg's Avatar
Default Re: (Andres-eh2)
I have the same noise i think mine is the cv joint (axle).
Old 07-25-2006, 07:59 AM
racingponys's Avatar
did you check the tie rods and the ball joints. Also make sure the cv shaft is all the way into the transmission.
Old 07-25-2006, 08:02 AM
instructor74's Avatar
Default Re: (spoonracer84eg)
check your upper and lower ball joints had same problem
Old 07-25-2006, 02:16 PM
Lissav's Avatar
Default Re: (instructor74)
Thanks for all the suggestions, it turns out that the backing plate that's supposed to be glued to the brake pad, wasn't glued on, therefore during light braking it vibrated and made the clunking sound.
Old 07-25-2006, 05:38 PM
Solbros Owns Me
Evs-One's Avatar
Default Re: (Lissav)
Old 07-25-2006, 05:47 PM
fizeks's Avatar
Default Re: (Evs-One)
im going to have to say your axle... mine did the same thing.. when i braked i heard and kinda felt grinding and somewhat knocking.... it turned out to be the passenger axle... the boot was like ripped apart and u could see the bearings and no grease was left in there... changed it out and problem gone. just check them out
edit:: nvm lol you already fixed the problem gj
Old 07-25-2006, 06:26 PM
96-EJ6 B18C's Avatar
Are you sure you got the 32mm axle nut nice and tight? Also, check the wheel bearing by hacking the car up and wiggling the top and bottom of the wheel in and out, it shouldn't move at all.
Old 07-25-2006, 06:36 PM
Unceasing Measure
Archidictus's Avatar
Default Re: (fizeks)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fizeks &raquo;</TD></TR><TR><TD CLASS="quote">im going to have to say your axle... mine did the same thing.. when i braked i heard and kinda felt grinding and somewhat knocking.... it turned out to be the passenger axle... the boot was like ripped apart and u could see the bearings and no grease was left in there... changed it out and problem gone. just check them out
edit:: nvm lol you already fixed the problem gj</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96-EJ6 B18C &raquo;</TD></TR><TR><TD CLASS="quote">Are you sure you got the 32mm axle nut nice and tight? Also, check the wheel bearing by hacking the car up and wiggling the top and bottom of the wheel in and out, it shouldn't move at all.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lissav &raquo;</TD></TR><TR><TD CLASS="quote"><FONT COLOR="red">Thanks for all the suggestions, it turns out that the backing plate that's supposed to be glued to the brake pad, wasn't glued on, therefore during light braking it vibrated and made the clunking sound.</FONT></TD></TR></TABLE>
Old 07-25-2006, 07:03 PM
Default Re: (Archidictus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus &raquo;</TD></TR><TR><TD CLASS="quote">Quote, originally posted by Lissav »
Reading &gt; me.
Old 07-30-2006, 01:04 PM
Default Re: knocking noise when braking (racingponys)
the fact of the matter is, it's a process of elimination.
For the most part, all of the above posts are right on target.
Carefully, review each part mentioned above and you will find your answer.
a shake while braking isn't always a warped rotor... it could be a tie rod bushing.
Old 07-30-2006, 03:00 PM
iLOVEmyEMone's Avatar
warped rotor?
HC4
Honda CR-V & Element
07-04-2019 05:45 AM
2gnarly
06-26-2011 09:43 AM
raidacaipo
09-09-2010 05:59 PM
lazychina
08-20-2008 05:45 PM
Quick Reply: knocking noise when braking
