Knock Sensor Problem 2000 Civic EX
Old 01-22-2008, 05:07 PM
etcinfected's Avatar
Default Knock Sensor Problem 2000 Civic EX
I have a CEL code #23 and that is the Knock Sensor. I already replaced my knock sensor like two days ago and I'm still getting the same CEL code #23. When I first took off my old KS, it was broken in two. So I thought I would replace it with a new KS and it'll get rid of the CEL code, but apparently it didn't. Now, I'm just clueless on what to do next. The car is a stock d16y8 motor with 93, XXX mileage on it. And on top of that, everytime I drive it, it seems it has no power at all. I know for sure the KS has to do with the v-tech and other related power issues. I really need help on what to do cause I have to get rid of the CEL and get it smogged. Please help me out! Thanks.
Old 01-22-2008, 05:19 PM
ifIexplode's Avatar
Are you sure you plugged the connector in all the way? I know the knock sensor is a bitch to get to under the Intake manifold.
Or did you reset your ECU?
Is there a krimp in the wire?
And with that Code your car is going into Limp Mode. The reason for No power, Or VTEC
Old 01-22-2008, 06:24 PM
Default Re: (ifIexplode)
I resetted the ecu and it still gave the CEL code #23. However, I haven't check whether its plugged in tightly and all the way through or if there's a krimp in it. I'll do that tomorrow and see what's going on. Thanks for the reply. I'll report back and see what's going to happen.
Old 01-22-2008, 07:50 PM
ek-g6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ifIexplode &raquo;</TD></TR><TR><TD CLASS="quote">Are you sure you plugged the connector in all the way? I know the knock sensor is a bitch to get to under the Intake manifold.
And with that Code your car is going into Limp Mode. The reason for No power, Or VTEC</TD></TR></TABLE>
thats true, and knock sensor are fragile, i was putting one in my friends y8 and it broke, but luckily i had another one. check the wires, to see if its cut or frayed.
Old 01-26-2008, 08:35 AM
I checked the plug, the wire, the screw, and replugged again. Everything seems to be in good condition. However, the CEL code #23 keeps coming on. I don't know what would it be now. Do you think it might be the ECU? I have a 99 ex ECU and my car is a 00 civic. Would that matters?
Old 01-26-2008, 01:00 PM
Anyone can help me?
Old 01-27-2008, 09:54 AM
I need a some help.
Old 01-27-2008, 11:48 AM
03akkord5spd's Avatar
the 99 and 00 ex ecu is the same, so that shouldn't be the issue unless the ecu itself isn't working correctly.
B16CivicEX
07-03-2006 04:58 PM
R_Machine
09-10-2005 11:59 PM
sir2sol
04-01-2005 04:55 PM
TRhatchCRAP
10
08-10-2003 11:52 AM
Sachmo
06-10-2002 01:23 AM
Quick Reply: Knock Sensor Problem 2000 Civic EX
