JDM D15B VTEC DIZZY
Old 05-21-2008, 08:35 AM
1fast_Shoebox's Avatar
Default JDM D15B VTEC DIZZY
What distributor does a JDM D15B use? its a 95 engine in a 92 CX. I'm not getting spark and I'm thinking this is my problem. I have replaced plugs, cap, wires, and rotor button. The cap and button are the only parts that were Z6. The spark plugs were a different part number than the Z6 and wires from a Z6 didn't fit.
I thought that the D15B and Z6 heads were identical, but I must be wrong.
What US parts are equivalent.
Old 05-21-2008, 08:39 AM
-[95cxhatch]-'s Avatar
Default Re: JDM D15B VTEC DIZZY (1fast_Shoebox)
i'm not sure which us part you could use.. prob z6 if you have a tach
but... try replacing the igniter before the distributor. It's the small greyish thing you see wires connected to when you pull the cap off.
Old 05-21-2008, 09:26 AM
speedooo's Avatar
Default Re: JDM D15B VTEC DIZZY (-[95cxhatch]-)
92-95 jdm d15bs use a z6 head/dist
Old 05-21-2008, 09:33 AM
baller status's Avatar
It's the same as the Z6/Z1/ZC. Having the wrong distributor wouldn't cause a no-spark condition. It causes the timing to be retarded even when adjusted to the max.
Old 05-21-2008, 11:27 AM
obuhmyuh's Avatar
Default Re: JDM D15B VTEC DIZZY (baller status)
uses the z6 dizzy. im using my old z6 dizzy on my jdm d15b.
Old 05-21-2008, 11:38 AM
cashkeith's Avatar
you surew its not get spark or is it not geting fuel bc you can use a z6 dizzy
Old 05-24-2008, 04:15 PM
Default Re: JDM D15B VTEC DIZZY (cashkeith)
plugs stink of fuel. no spark whatsoever. Check engine light stays on. I ran it on my cx ecu for a few days. Changed to the D15B ECU and so spark since. Tried old ECU and still no spark....
DaCivicSWAP
06-14-2012 12:56 PM
twizted-myatt
06-17-2011 02:23 PM
dirvin7588
05-09-2011 05:02 AM
slob20ef
05-18-2009 06:14 AM
94c1v1cex
07-16-2007 01:12 PM
Quick Reply: JDM D15B VTEC DIZZY
