Camber Kit question
Old 02-22-2005, 01:52 PM
arnold1980's Avatar
Default Camber Kit question
wassup bros, i had a quick question and i thank you in advance for any advice. I originally had neuspeed race springs (2 inch drop/rear 2.5 drop/front) I exchanged these springs for H & R OE sport springs. .75 drop.
I had purchased a skunk 2 extreme camber kit (for cars dropped over 2 inches) but i never put it on. My question is would this camber kit work for the H & R springs even though its a lesser drop than 2"? Should i install the kit or just sell it?
Thanks
~~Arnold~~
Old 02-22-2005, 02:02 PM
I am a (Trial User) Army
litterbox's Avatar
Default Re: Camber Kit question (arnold1980)
The camber kit will work, but you don't need it. If you ever plan to swap springs for something lower, then it would be a good idea to have. I would put it on.
Old 02-22-2005, 04:20 PM
arnold1980's Avatar
Default Re: Camber Kit question (litterbox)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by litterbox &raquo;</TD></TR><TR><TD CLASS="quote">The camber kit will work, but you don't need it. If you ever plan to swap springs for something lower, then it would be a good idea to have. I would put it on.</TD></TR></TABLE>
so you don't think a .75" drop will negatively affect the camber?
Old 02-22-2005, 04:34 PM
Kyles ej1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by arnold1980 &raquo;</TD></TR><TR><TD CLASS="quote">so you don't think a .75" drop will negatively affect the camber?</TD></TR></TABLE>
hell no i went more than twice that and my camber is fine, no wear at all in 7 months
Old 02-22-2005, 06:14 PM
j-specB20sol's Avatar
just remember... its not really the camber that is jacking up your tires... its the toe. Shops can fix the toe without a camber kit...
Old 02-22-2005, 06:16 PM
eK9aT10pSi's Avatar
Default Re: Camber Kit question (j-specB20sol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by j-specB20sol &raquo;</TD></TR><TR><TD CLASS="quote">just remember... its not really the camber that is jacking up your tires... its the toe. Shops can fix the toe without a camber kit... </TD></TR></TABLE>
finally someone actaully knows the "secret" on how dropped cars [not slammed] dont need camber kits. but yes it is very true, get your toe set and your good. oem civic camber range is -1 &lt;&gt;+1
Old 02-22-2005, 06:33 PM
AutoXer's Avatar
I'm running over 2* in the rear (you can see the camber) and nearly 2* in the front with no wear; but I got an alignment right after I installed my springs. I run summer performance tires and have a seperate set for the track. 1 year, no wear problems. I actually need to get a camber kit to dial in more camber on track days because I'm scrubbing the outside shoulder of my Falkens.
Camber doesn't kill tires, toe does. Get an alingment every time you touch your suspension.
Old 02-23-2005, 12:20 PM
dubzxallxstar's Avatar
Default Re: Camber Kit question (EX_AutoXer)
are u from the so cal ... if u are do u know any places that align lower cars....because i dont....would u know any places ..thanks...
Old 02-23-2005, 12:50 PM
AutoXer's Avatar
Default Re: Camber Kit question (dubzxallxstar)
No, sorry. When I lowered mine, I had to bring it into the body shop (was hit by a plow right before) and asked them if they had an alignment station. They didn't, but they contracted their work out with a shop down the street.
I'd look in the yellow pages and start calling performance shops that do work. There has to be one around somewhere.
Old 02-23-2005, 03:55 PM
arnold1980's Avatar
Thanks for the responses. Top notch replies.
Since i'll stick with the H & R springs i'll prolly just sell my camber kit.
~~Arnold~~
Eg6xCiViCxSi
Suspension & Brakes
02-25-2008 12:27 PM
kraaaaap
20
07-06-2007 09:14 AM
mikeunreal
Suspension & Brakes
26
11-21-2005 01:47 PM
dawrenn
Suspension & Brakes
31
01-26-2005 09:52 AM
uNF$@#!
05-05-2002 12:48 PM
Quick Reply: Camber Kit question
