wats the fastest swap 2 do with turbo?
Old 01-13-2009, 07:26 PM
skillzhb's Avatar
Default wats the fastest swap 2 do with turbo?
hey i wonna no wat you guys think iam doing an eg project this summer and i dont noo wat motor 2 go with i was thinkin ls/vtec cuz it has top and low end powerr with a turbo but i donttt no wat 2 doo my friends have like 350hp 2 the wheels and i need 2 win lol help let me no wat motors u guys think not 2 pricey tho
skillzhb is offline
Old 01-13-2009, 07:31 PM
quicchatch253
Guest
Posts: n/a
Default Re: wats the fastest swap 2 do with turbo?
h22a
Old 01-13-2009, 07:32 PM
v8 integra's Avatar
i would..get a lsvtec...build it from top to bottom and then turbo....
v8 integra is offline
Old 01-13-2009, 07:43 PM
skillzhb's Avatar
it wont blow on me wat if i put the turbo with a lil upgrades or stock?
skillzhb is offline
Old 01-13-2009, 07:44 PM
KillBot's Avatar
Dart block + 35psi or so...or is your car a daily?
Built K24 block...not enough cash?
.............ect...ect...ect......
What are you going to do with this car, besides try to beat your friend who has 350 whp?
KillBot is offline
quicchatch253
Guest
Posts: n/a
it will blow
h22a will not
ls/v succs
h22a does not
ls/v makes 200whp with turbo
h22a makes 80000whp with turbo
Old 01-13-2009, 07:45 PM
skillzhb's Avatar
summer car only but iam makein it track use to. roll cage gutted n ****
skillzhb is offline
Old 01-13-2009, 07:49 PM
T3KNiQe's Avatar
Originally Posted by quicchatch253
h22a
The piston heads scrap the walls when you boost an H22a....
And I wouldn't recommend an Ls/Vtec for boost, sounds like problems...
I recommend an Ls, and depending what kind of turbine you get should really determine what tranny you need. Most people just go with an Ls tranny, but if you got a small turbine and aren't puttin down that much you could get away with a GSR tranny....or B16 tranny but it must have LSD (I prefer aftermarket LSD) cause the gears are to short...
T3KNiQe is offline
Old 01-13-2009, 07:54 PM
skillzhb's Avatar
wat bout the b20z i might go with the t3/t4 turbo
skillzhb is offline
Old 01-13-2009, 07:57 PM
quicchatch253
Guest
Posts: n/a
what the fucc are you talking about
two of my homies got boosted h22a's and have no problems
Old 01-13-2009, 07:59 PM
T3KNiQe's Avatar
Yeah I know they have no problems, just tell them to put some miles on that setup then take the engine apart then you'll see what the fucc I'm talking about.
T3KNiQe is offline
Old 01-13-2009, 08:04 PM
quicchatch253
Guest
Posts: n/a
how much miles? one of my homies got 30k on his and we took apart his motor n nothin was wrong wid it cuhzzin
Old 01-13-2009, 08:12 PM
skillzhb's Avatar
helppp me not beef
skillzhb is offline
Old 01-13-2009, 08:15 PM
KillBot's Avatar
Wow...
KillBot is offline
Old 01-13-2009, 08:18 PM
skillzhb's Avatar
wats wow?
skillzhb is offline
Old 01-13-2009, 08:47 PM
arrocha87's Avatar
yea wow is all ima say but yea id go with built LS, best for boost in my opinion...
arrocha87 is offline
Old 01-13-2009, 08:51 PM
No VDUBS here in206's Avatar
Originally Posted by arrocha87
yea wow is all ima say but yea id go with built ls, best for boost in my opinion...
x2
No VDUBS here in206 is offline
HondachrisEJ1's Avatar
wow a lot of BS going on here.
Each engine platform has advantages and disadvantages when it comes to a turbo.
LS/Vtec can be troublesome and complicated especially for someone who hasn't run through it before. Add a turbo and you compound the problems...oil and compression mostly. Many of these blow up within the first 40k because of an inexperience builder or neglect. Have seen well built ones last 100k+(still alive) under extreme pressures of road track racing.
B20/Vtec-Amazingly easy to get 350 but like the ls/v it lends it self to problems when neglected or poorly built.
H22a has issues with finding proper pistons for replacement. not just any forge piston can go in due to the cylinder walls they have to have a special coating or alloy. Or you can resleeve. Good turbo vtech platform beyond that. Unlike B series your tranny options are pretty limited. Proper gearing can do a lot for you in a race including beating a car that heavily out matches you on a dyno. Also a heavier platform remember acceleration is a function of both mass and power commonly hp to weight ratio. if he has 350 on a b18 and you have 350 on an h22 (driver and chasis is constant) He will win I will put money on that.
LS doesn't have v-tec but does can be boosted pretty well without many problems. Easy to get parts for and relatively inexpensive. Smaller then the h22a means it will more difficult to get to 350hp with minimal lag or spool time.
B16a lends itself to be a great turbo base but is small and not as much torque. Have seen these things boosted to 375hp@14psi on stock internals (not recommended and I am frankly amazed it is still alive)
K-series- Expensive (tune, parts, swap etc)- but wont take as much to beat 350hp
Either way to reach 350 hp you will need a bottom end if you want it to last long. Do your research because each way you go you will find obstcals at that power. And balanced approach is far better then a focused approach
HondachrisEJ1 is offline
skillzhb's Avatar
ighttt thanks man
skillzhb is offline
Old 01-13-2009, 08:53 PM
h22a boost is pretty quick too, step bro had one and i almost needed neck brace after lol
Old 01-13-2009, 08:56 PM
The Lobster's Avatar
h22a can boost...easily...
ls/vtec when built right is great. bro had 420 hp but not the point.
if i were you and money is tight.
eagle rods + vitaras + your block = 350-400 hp for cheap
The Lobster is offline
Old 01-13-2009, 08:59 PM
skillzhb's Avatar
ya i think i might go with ls/vtec ill let you guys no whan its done thanks alott
skillzhb is offline
Old 01-13-2009, 09:02 PM
One more consideration.....G23...
http://www.importtuner.com/tech/impp...dge/index.html
If you keep the h22 head perfect for boost!
Old 01-13-2009, 09:04 PM
Master Detailer
98civdx's Avatar
it will blow
h22a will not
ls/v succs
h22a does not
your kiding right?
98civdx is offline
Old 01-13-2009, 09:05 PM
gizzerhatch's Avatar
h22's are bad for boost. they have fiber reinforced side walls thats why they dont like boost.
gizzerhatch is offline
Quick Reply: wats the fastest swap 2 do with turbo?
