how to tell master cylinder is bad
Old 02-23-2005, 03:18 PM
ice11honda's Avatar
Default how to tell master cylinder is bad
My brake pedal is getting soft so I decided to bleed my brakes. Front pads are new and the rear looked very good. So I go to bleed the brakes and the driver side drum brake and the bleeder screw brakes on me. I went ahead and bleeded the other 3 sides but my pedal still goes to the floor. Their is only air bubbles in the passenger rear when bleeding.
So my question is: 1. Is it possible to effectively bleed lines with 3 bleeder
screws?
2. How can I tell if my master cylinder is bad, or brake booster whatever that is?
Old 02-23-2005, 08:00 PM
blurrrcivic94's Avatar
To test the brake booster, pump the brakes while the car is turned off. If the pedal gets stiffer with each pump, then your brake booster is fine.
Old 02-23-2005, 08:05 PM
Mr. Badwrench
boostedcivicsir's Avatar
Default Re: how to tell master cylinder is bad (ice11honda)
once you get all the air out, rest your foot on the pedal. if it sinks, you will need to replace. it is not uncommon for this to happen.
Old 02-24-2005, 11:31 AM
hatchi's Avatar
have you checked if your wheel cylinder is leaking??
Old 02-24-2005, 12:56 PM
_BEN_'s Avatar
Default Re: how to tell master cylinder is bad (hatchi)
It would be very difficult to bleed all of the air out of the system if you cant bleed one of the wheels.
I have had a mc go bad and it would hardly push fluid to the back wheels. The rear brakes would not work at all just the fronts.
DerekHollister
24
09-15-2017 03:17 PM
5rivers
10-10-2015 06:44 AM
kelviiv
10-23-2010 05:04 PM
GSR95T
09-04-2002 09:21 AM
highmilehatch
06-19-2002 09:14 PM
Quick Reply: how to tell master cylinder is bad
